need a GM part number for speed nuts
Old May 5, 2013 | 09:29 PM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
Hey Guys,
So, I pulled the door panel off of the inside of the door of my 91. I need the replacement speed nuts that attack the cardboard door panel to the plastic molding on top.
The nuts I need are pictured here
http://www.1aauto.com/1A/Weatherstri...SS00097/329666
in the second picture.
I bought similar nuts at Lowe's, but although the hole in the center of the nut is the right size, the lip around the nut isn't wide enough.
I tried contacting 1Aauto, but they don't sell the nuts individually. I guess I'll need to purchase them through GM.
Thanks in advance for your help!
Bill
Old May 6, 2013 | 12:37 PM
Yenipenny's Avatar
Car: 92 RS Heritage
Re: need a GM part number for speed nuts
I'm 99.99% sure that GM doesn't sell those individually either. There are other fastener companies that do have them. A GM dealer or body shop may have those but they didn't buy them from GM.
Old May 6, 2013 | 02:45 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
I know up here they sell assorted kits of them at the local canadian tire store as Ive seen them here. its been awhile but I assume they are stil there. Try your local auto parts store
Old May 6, 2013 | 05:31 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Did you try this site?http://www.clipsandfasteners.com/Nut...31.htm,I'm sure they have what you need
Old May 6, 2013 | 06:10 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Did you check the Help section or whatever it's called at your local parts store? The area with all the oddball parts in the little cardboard hangers? The stores by me have all kinds of door handles, window cranks, radio ***** and stuff. Sorry, not sure how else to describe that aisle.
Old May 6, 2013 | 06:16 PM
wgripp's Avatar
Thanks for the suggestings guys. I checked Autozone, Napa, O'Reilleys, Lowe's, and Advance. Most of them have speed nuts, but they dont have the right washer size.
I think the GM part number is 1680050. It's been discontinued. Most websites dont' seem to stock it. I've sent out a few emails in search of the part. Wish me luck.
How come every time I take something apart, some screw, washer, nut, etc. disappears or some plastic tabs snap off, and I get set back two weeks waiting for a replacement?
Old May 6, 2013 | 07:11 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Originally Posted by wgripp
...How come every time I take something apart, some screw, washer, nut, etc. disappears or some plastic tabs snap off, and I get set back two weeks waiting for a replacement?
Welcome to the wonderful world of working on older cars
Seriously though, good luck with the search, and if you do find a source for them, be sure to post a link. I'm sure you're not the only member here who needs some replacements.
Old May 6, 2013 | 07:52 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Your GM part # is correct for the speed nuts. I found this place that carries them.
http://www.car-pak.com/Fasteners/c22...duct_info.html
They sell them in a pack of 100 but they are really cheap. Guess you would have to call them or send them an email to see about buying them.
Old May 6, 2013 | 11:40 PM
wgripp's Avatar
Jermdm, thanks for finding this. I already emailed car part. According to their website, they only sell to stores/distributors. I asked them to point me towards a store that will sell me nuts.
Bill
Old May 7, 2013 | 01:10 AM
mantaguy's Avatar
Engine: 5.0 EFI
I will check my spare parts for them,I replaced my inner window weatherstripping's from 1A last year,I should have them.Let you know later today.
Old May 7, 2013 | 03:46 PM
mantaguy's Avatar
Engine: 5.0 EFI
This is all that I have,4 originals(small) and 4 replacements(larger,but the holes are the same).If you want them PM me.
1992 Trans Am
May 10, 2023 07:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
IrocZ'85
Aug 17, 2015 06:24 PM
TA8487
Aug 16, 2015 12:21 PM
armybyrd
Aug 10, 2015 09:23 PM
