How to remove heater / AC controls?
How can I remove the heater / AC controls? These are interchangeable between all thirdgens right?
Whenever I've been to the junkyard, I can remove everything except for this part of it.. (View image)..
But I don't know how to remove it or how I would put it back on. I would rather not cut and splice those wires.
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: How to remove heater / AC controls?
Not all heater/ac controls are interchangeable. I believe the later models had high speed relay for the blower fan.
I used the Firebirds Parts CD not the Camaro one but I'm showing heater control for 83-89, 90-92. I'm too lazy to dig out the Camaro one also.
Looks like the #4 part you are questioning is the Air Valc Actr Vac Harness part 14101552 (from 91-92 F Body with C60 [Air Conditioning]). Looks like it has various vac connections and possibly ties back into the other harness for the controls.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Two small push nuts hold the harness in place on the long studs. On the outside of the studs underneath are two small screw/bolts. BTW, at some point the following link will be useful:
https://www.thirdgen.org/forums/inte...anent-fix.html
JamesC
JamesC
The_Phoenix
Feb 4, 2016 07:10 AM
