Mechanic unplugged some stuff under dash, trying to find where they go
Old May 19, 2013 | 03:03 PM
Firechicken86's Avatar
Car: 1989 Trans am GTA
Transmission: t56 6 speed
Axle/Gears: 3.45
I brought my car to the shop to do a t56 swap and they changed out the pedal assembly to the t56 one and didn't plug these things back in and am trying to put them back. It's these three things here:
This one is a rubber hose and attached to it is a plastic switch.
If you guys could help me put these back in to place I would appreciate it greatly
Old May 19, 2013 | 03:11 PM
82tarecaro's Avatar
Re: Mechanic unplugged some stuff under dash, trying to find where they go
The one with the rubber hose is for the cruise control. I can only guess that the other two might be the clutch interlock switch - so you don't start the car in gear, and the other one is possibly the brake light switch.
Old May 19, 2013 | 03:30 PM
Axle/Gears: 3.45
Thanks a lot! do you know what the cruise control switch mounts to?
Old May 19, 2013 | 03:47 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
The white one with the 2 plugs is the brake switch which cuts the cruise signal and also works the brake lights. The one with the hose is the vac cutout for the cruise. Each goes in one hole on the brake pedal bracket. I believe one may be larger than the other.
As for the last one, don't have a clue. Seems to me there should only be 2 switches on the pedal assembly that are actuated in that manner... The third (on the pedal mount, not in your pics) has a big fat purple and big fat yellow or green wire in it and that one IS the clutch safety switch.
Old May 19, 2013 | 07:17 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
I just put one in my car,their's a bracket with two holes in front of the brake peddle arm,they will have a steel sleeve that holds the switches in place.
The one with the vac line you show seems to be broken,their should be electrical plugs on it.
Old May 21, 2013 | 12:45 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
The white one with the 2 pigtails is the stop light switch. Surprized he didnt kill your battery or noticed your brake lights where on the entire time. Id question how the tranny was put in if something as simple as that was left unseen
Old May 21, 2013 | 08:25 PM
shaubloom's Avatar
Car: 1988 Pontiac Formula Firebird V8 5.
PLEASE help me find where to plug this in!
Can someone help me find where to plug this in? I have been looking and searching and can't find anything. I'm pretty sure it has something to do with my cruise control, however I am unsure. Any ideas? There is a picture of the plug and one of under the dash for reference.
Attached Thumbnails Mechanic unplugged some stuff under dash, trying to find where they go-imag0318.jpg   Mechanic unplugged some stuff under dash, trying to find where they go-imag0324-1.jpg
Old May 22, 2013 | 09:31 AM
Kingsobieski's Avatar
Looks like some aftermarket stuff was installed - like a security alarm or remote starter.
Old May 22, 2013 | 10:56 AM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Re: PLEASE help me find where to plug this in!
Like Kingsobieski said, looks to be something aftermarket. I don't know of any factory wiring that uses a spade like that. Also the inline fuse in the wiring photo is a dead giveaway that you've got some aftermarket electronics.
eightsixseven
Dec 16, 2024 01:50 PM
Jorlain
Aug 24, 2022 05:11 PM
Vintageracer
Jan 10, 2020 05:33 PM
gta90
Sep 15, 2015 04:00 PM
justin57
Aug 20, 2015 07:05 PM
