86 camaro help
Old Jun 5, 2013 | 10:44 PM
2004chevyman's Avatar
Car: 1986 camaro
Engine: 2.8
Transmission: 700r
Axle/Gears: 243
86 camaro help
trying to explain this in the rt way so people can understand ,if you have owned or seen a 86 camaro then you will know what i'am talking about,i hope, but in the hatch area you have the side pannels they are some kind of hard plastic.i have used dye on door pannels before but it dont last long before it starts to peel off and it really looks like s**t if you know what i mean ,but with all this new stuff what can i use now that will not peel and looks like i purchased new pannels ,if there is anything at all ,if not where can i purchase new or reman parts thanks for any help at all i'am trying to restore this car and i want everything to look or be new ,hope someone can help me with this post
Old Jun 5, 2013 | 11:44 PM
86_irocz-28's Avatar
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Re: 86 camaro help
Duplicolor vinyl plastic. Scratch the panels up with greeny pad, hot water and soap, grease and wax remover, prep spray, then hit it with paint worked great on mine
Old Jun 5, 2013 | 11:55 PM
Car: 1986 camaro
Engine: 2.8
Transmission: 700r
Axle/Gears: 243
Re: 86 camaro help
thanks was bangging my head on the wall,in the pic what all did you do ,if you did the dash and console it does a great job if you did not do that can you show me some pic of what you did thanks
Old Jun 6, 2013 | 12:02 AM
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Re: 86 camaro help
dash, console, door panels, and all other panels were dyed or "painted" but done the right way
Old Jun 6, 2013 | 12:24 AM
Car: 1986 camaro
Engine: 2.8
Transmission: 700r
Axle/Gears: 243
Re: 86 camaro help
witch one was it dyded or painted but it looks great
Old Jun 6, 2013 | 12:46 AM
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Re: 86 camaro help
Duplicolor vinyl fabric most call it a dye but its in a spray can
Old Jun 6, 2013 | 12:55 AM
Car: 1986 camaro
Engine: 2.8
Transmission: 700r
Axle/Gears: 243
Re: 86 camaro help
thanks man will try it and send you some pic when i'am done
Old Jun 6, 2013 | 11:19 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: 86 camaro help
Don't waste a nickel on spray dye or another minute contemplating your plan of attack. Based on what you wrote, you will NOT be happy unless the panels are the correct color,... buy some used panels that are the color you are looking for.
If your current interior plastics are badly scratched and dry-rotted than you've got nothing to loose by spraying them with vinyl/fabric dye. Go-ahead and give it a shot. Dying works best if your trying to stay with a "similar" color, and will only be as "successful" as possible with proper preparation.
If your current interior plastics are in good shape then don't ruin them by spraying them. Sell them to someone else that wants them. ANY $$ you get will help pay for the parts you want. ( the parts that will not get harmed the first time they get touched by something harder than a milk carton ! )
I use spray dye all the time; almost exclusively on fabric or rubber parts. Wanna' see what happens to spray dye on plastics, OK. Now: I know better,...... but in this case I need to get belts in the car. (There's no headliner so they can get replaced before the headliner gets installed. ) I used liquid dye to dye the belts first then I used spray dye over the belts and the plastic. The plastic housing got washed with water, then Super clean, then water, then a wet green scrubby, then dried, then sprayed. As I was carrying them to the car for installation the metal belt made contact with the plastic.
If your gonna' do it,.....................
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
