145 mph speedo in camaro base cluster
Old Jun 5, 2013 | 03:30 AM
PlaneJane88's Avatar
Car: 88 Camaro
Engine: 305 tbi
Transmission: t5
Axle/Gears: 9 bolt with 3.27s
Swapped a 145 speedo in my 88 sport coupe. Test drive revealed it was reading way fast. Any suggestions on how to fix this problem? Does it matter if it comes from and auto or manual car?
Old Jun 5, 2013 | 06:17 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 145 mph speedo in camaro base cluster
Welcome to TGO, PlaneJane.
No.
Perhaps something here:
https://www.thirdgen.org/forums/inte...eedo-woes.html
JamesC
Old Jun 6, 2013 | 03:04 AM
Car: 88 Camaro
Engine: 305 tbi
Transmission: t5
Looking for something a little more specific to my problem. I appreciate the help, but has anyone run into this problem and how did you fix it?
Old Jun 6, 2013 | 06:39 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
the 145 mechanical speedo is a direct swap into the cluster, no other changes needed
I see you've got a 9 bolt with 3.27 gear. Was the speedo drive gear in the trans swapped to match? and was the old speedo reading correctly?
Old Jun 6, 2013 | 06:43 AM
Car: 88 Camaro
Engine: 305 tbi
Transmission: t5
Rear came from a trans am and the speedo came from eBay.
Old Jun 6, 2013 | 06:48 AM
naf's Avatar
naf
Sweet. Didn't know that.
Were the speedometer gears in the transmission tailhousing swapped out for the proper gears when you swapped to the 3.27?
Old Jun 6, 2013 | 06:55 AM
Car: 88 Camaro
Engine: 305 tbi
Transmission: t5
The car the rear came from was an auto and mine is a stick
Old Jun 6, 2013 | 06:57 AM
JamesC's Avatar
As I mentioned in the above link, a rear change, if the ratio is different from the original, will affect the speedo reading.
JamesC
Old Jun 6, 2013 | 07:15 AM
Car: 88 Camaro
Engine: 305 tbi
Transmission: t5
It was still off with my original rear and that had 3.08s.
Old Jun 6, 2013 | 07:38 AM
naf's Avatar
naf
Auto or manual makes no difference.
If it was off with the original rear end, it may be bad. Everything outside of the speedo unit is the same for either the 85 MPH speedo or the 145 MPH speedo, assuming both were stock mechanical units (round face).
Try the original speedo and see how it reads.
Post a pic of this 145 speedo.
Old Jun 6, 2013 | 09:13 AM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
88 sport coupe V6 likely came from factory with 3.42 rear
At least mine did.
Old Jun 6, 2013 | 09:17 AM
W.E.G.'s Avatar
Engine: V6 2.8
What is you GUx RPO code?
Old Jun 6, 2013 | 11:02 AM
Car: 88 Camaro
Engine: 305 tbi
Transmission: t5
I'd have to go look later for the rpo code. Its a tbi with a stick
Old Jun 6, 2013 | 11:03 AM
Car: 88 Camaro
Engine: 305 tbi
Transmission: t5
And has 115 MPH speedo and its spot on with the original rear
Old Jun 6, 2013 | 11:15 AM
JamesC's Avatar
I'd guess the 145 speedo head is faulty.
JamesC
Old Jun 6, 2013 | 11:27 AM
Car: 88 Camaro
Engine: 305 tbi
Transmission: t5
Anyone know of a good place to get it rebuilt? I got it cheap cause to cause the trip is broke
Old Jun 6, 2013 | 11:36 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Don't assume anything, & don't waste time chasing codes.
Verify what the the rear end gearing is, then remove the VSS and verify the speedo DRIVE and DRIVEN gears that are currently in use. This should take no longer than 15 minutes of your time. Once you are SURE that these are all MATCHING parts,... then begin to think about the cable or speedo head as possible problems.
I *think" the 3.27 with T5 should be a red 7 tooth DRIVE gear and a brown 18 tooth DRIVEN gear. Double check to be sure !
Old Jun 6, 2013 | 03:02 PM
naf's Avatar
naf
or maybe a 145 overlay was placed on an 85 unit
Old Jun 6, 2013 | 03:40 PM
Car: 88 Camaro
Engine: 305 tbi
Transmission: t5
Car is an 88 plane jane. 305 tbi with a stick. If the rear that was in it was original to the car, gears are 3.08s. Its possible if the guy I got the speedo put the overlay on a 115 speedo cause doing like 80-85 in the car the speedo was reading 120.
Jorlain
Aug 24, 2022 05:11 PM
Jeremys87
Jul 14, 2022 09:08 PM
tnrednneck
Aug 13, 2015 08:57 AM
ChevyZ71
Aug 13, 2015 07:30 AM
Irocohio
Aug 12, 2015 08:03 AM
