how do you take off the Inner Door Panel Top Rails
Old Jun 8, 2013 | 01:31 PM
tcrisp's Avatar
Car: 1989 camaro iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 323
How do you take off the Inner Door Panel Top Rails with out breaking them?
Attached Thumbnails how do you take off the  Inner Door Panel Top Rails-door-001.jpg
Old Jun 8, 2013 | 01:40 PM
89RAG's Avatar
Car: 89 IROC-Z CONVERTIBLE
Engine: 5.0L TPI
Re: how do you take off the Inner Door Panel Top Rails
thought those came off with the whole door panel?? i've had mine off several times and always come off in one piece. i always lift and tilt the panel towards the window, pull up and the clips release
Old Jun 8, 2013 | 01:45 PM
Javier87z28's Avatar
Car: 1987 Camaro Z28, 1989 TTA #922
Engine: lb9, 3.8L turbo
Transmission: 700r4, 2004R
If im not mistake the window should be rolled all the way down in order for them to come out
Old Jun 8, 2013 | 02:13 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
They are supposed to come off with the rest of the door panel. Like many others (myself included) that didn't know beforehand, tcrisp has torn the mounting points for them off of the door panel, leaving just the top black trim part.
See this thread for proper removal https://www.thirdgen.org/forums/inte...move-door.html
Old Jun 8, 2013 | 04:47 PM
tcrisp's Avatar
Engine: 350 tpi
Transmission: auto
Axle/Gears: 323
will the door panel still stay on now sense they are torn at the top . If not how do i fix it.
Old Jun 8, 2013 | 05:39 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
I hope that their just stuck,and someone didn't glue them down.
Old Jun 9, 2013 | 07:14 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
If you tore the door panel away from the top rail you can refasten
it.
Remove the top panel by lifting it up and sliding it forward or
backwards to release it from the holding clips................
Since you ripped the panel from the top rail..........
Get a pop rivet gun and a small drill bit.
You should be able to slide the panel into place in the top rail.
Drill several holes in the HIDDEN area of the top panel and
door panel and pop rivet them together.
If done correctly you won't see the pop rivets...........
I did this on my 84 as the PO tore the panel off the top rail.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Out-Cast
Aug 23, 2015 06:33 AM
