NEED HELP ASAP PLEASE (TRUNK LATCH)
Old Jun 23, 2013 | 10:24 AM
scagz2.8l's Avatar
Car: 1988 camaro rs
Engine: 2.8l
Transmission: automatic
hi the motor on my trunk latch has been running non stop and it is stuck in the down position. I got it to move once by pushing the motor to the side to make the gear catch but that stopped working. I took the motor apart and then took the whole thing off the tracks. I feel like I shouldn't have done this and just made more work for myself. can someone please help me this is my daily driver and want to fix this before it rains. the battery is disconnected right now so the motor wont burn out.
Old Jun 23, 2013 | 10:26 AM
scagz2.8l's Avatar
Car: 1988 camaro rs
Engine: 2.8l
Re: NEED HELP ASAP PLEASE (TRUNK LATCH)
also I don't care if the electric motor is not functional when I am done I just want to be able to close it, is there a non motor latch I can buy or can I rig it to I just close the hatch?
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
http://www.top-downsolutions.com/
Old Jun 23, 2013 | 12:33 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
There is a switch that needs to get flipped when the motor goes up/down. If the adjustment is wrong the switch won't get flipped and the motor won't shut off. Or, if the gears are stripped, the mechanism won't move far enough to flip the switch. As said topdownsolutions has parts. Or folks selling units on the board.
1Aauto
Sponsored Vendors
Feb 8, 2017 03:09 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
92projectcamaro
Sep 24, 2015 08:09 AM
sylentnite
Sep 9, 2015 02:55 PM
