Stupid trunk latch..
Old Jun 30, 2013 | 10:31 PM
Ryan Wandell's Avatar
Car: 89' RS.
Engine: Carbureted 305.
Axle/Gears: 4.56
My 89' RS has an electronic latch for the trunk that doesn't work.. I'm guessing it's too seal the trunk water tight? Anyway, i've torn it apart and found that it's a huge unit.. is there any way I can swap that for a regular trunk latch, that will work just fine or does autozone sell these electric trunk motors? I've found one for 83.99 but it seems a little small for that huge mass of wires and junk thats there.
Old Jul 1, 2013 | 12:22 AM
robg91z's Avatar
Car: 1991 Camaro Z28
Engine: 350ci TPI
Transmission: built 700r4
Axle/Gears: 4th gen rear end
Re: Stupid trunk latch..
i have the same problem i wanna get rid of my electronic latch, what do u have to do to swap a regular latch
Old Jul 1, 2013 | 12:37 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
I think the bracket welded to the body is different but not 100% sure. Just put your electric hatch motor all the way down and use it like a non power one. Thats if it doesnt work. Its adjustable somewhat on the 3 bolts that hold it in
Old Jul 1, 2013 | 02:24 PM
Car: 89' RS.
Axle/Gears: 4.56
I've tried that, but it's got way too much play in it. The eletric to it works just fine the motors shot, so I may just put a new motor in it.. I was just thinking I could go back a few years and get a regular one.
Old Jul 1, 2013 | 07:45 PM
6SIX6's Avatar
Car: 89 IROC
I might have a motor kicking around that works or a spare hatch pull down motor if you just want to swap it out
Old Jul 1, 2013 | 10:12 PM
lmidden's Avatar
Car: 1987 camaro sc
Engine: lg4 305
take the entire assembly out get it into a position that looks like it will work drill 1 hole in each track all the way through and put a bolt in each hole thats what i did then i left the wiring harness disconnected when i put it back in
Old Jul 2, 2013 | 01:40 PM
zacw4328's Avatar
Car: 92 Camaro RS
Engine: 5.0 305 TBI
I feel y'all's pain. I've gone through 3 of these things. I honestly hate them. But luckily this third one is working perfect.
I looked at trying to switch to manual latch or whatever and read the latch is applied to the body different. So I just stuck with the electric. Sorry you're having the problem man.
1Aauto
Sponsored Vendors
Feb 8, 2017 03:09 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
djmarch
Oct 2, 2015 10:41 PM
sylentnite
Sep 9, 2015 02:55 PM
