Dash Panel
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Dash Panel
Does anyone know, if I remove this panel,would it give me access to the Front Speaker Wires.I lost sound in the Left Front Speaker and it is a SOB to trace the wires.What would this panel give me access to???
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
Re: Dash Panel
To answer your question, yes, it will.
After the dash mat comes the speaker, wires, etc..
Engine: 5.0 EFI
Re: Dash Panel
Thanks Guys,I went ahead and pulled the Radio Pod out and found my problem.behind the radio all the wires go to this block
and then the wires for the sound system,(UQ7) plug into that,I got lucky,the front speaker plug was loose at this box
The White center plug is for the front speakers,don't know why the Right Side was working(must have had enough of the plug connected to that side)
wigmobile
Feb 26, 2025 02:56 PM
