3rd Gen Taurus SHO seats
Old Jul 5, 2013 | 09:36 PM
IROCgiraffe's Avatar
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
Anyone know if dimensionally they will fit our 3rd Gens?
These things are VERY comfortable, and have a set of bolsters on them. I would like to try these in my IROC, not sure if someone else has already tried this.
They are large, but man are they comfy.
Old Jul 5, 2013 | 11:01 PM
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
Re: 3rd Gen Taurus SHO seats
Woah those look awesome! Make them fit
Old Jul 5, 2013 | 11:45 PM
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
too wide theyd probably fit but rub alot.
Old Jul 6, 2013 | 02:26 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Look at how they attatch to the floor as that could be the sticking point. Our stock seats sit very low, rasing them up much could put your head close to the roof.
Old Jul 6, 2013 | 02:28 PM
Engine: LB9 | LS1
I am aware the seat frame would have to be modified. I am tall, hence my screen name... they would never be raised :-)
Old Jul 6, 2013 | 02:32 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
....Our stock seats sit very low....
Not low enough, which is why a lot of us tall people put 4th gen seats in. Not only more comfortable but also gets our head out of the headliner.
If the width will fit, measure the space in the 3rd gen then measure the seat, then I say go fo it. Nice looking seats.
Old Jul 6, 2013 | 02:45 PM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
4th gens sit lower??? omg i need 4th gen seats then. my 93 yukon seats were too high so i put my black thirdgen ones in and now everyone who sits in it is surprised at the amount of head and leg room as well as it being more comfortable than the stock seats minus arm rest that is.
Old Jul 6, 2013 | 03:01 PM
Car: GTA
Yes. The 4th gen seats have shorter mounts + thinner pads, but no loss of padding. The 3rd gen padding is too stiff, IMHO.
The 4th gen seats are a 100% direct bolt-in but if you go with power seats you'll hafta redo the plugs, but no bit deal there.
Old Jul 6, 2013 | 04:54 PM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
You would have a better chance trying to squeeze in Bonneville seats which are similar to those. There's always leather grand am gt seats from the early 90s and up to check out. The earlier ones bolt right in. I say these because they are cheap, plentiful and look stock.
Early style:
Later:
Old Jul 6, 2013 | 04:57 PM
Engine: LB9 | LS1
I have access to a good set of the aforementioned seats....
Old Jul 6, 2013 | 10:12 PM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
i always wanted to try the bonne seats.
Old Jul 7, 2013 | 06:44 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Agreed, but as another member said, compared to other vehicles our seats sit low. Seats out of many other cars have many inches between the seat bottoms and the cars's floor pan.
Old Jul 7, 2013 | 04:04 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Early style:
Later:
the problem is the back seats won't match.fine for cars that have been tubbed.
Old Jul 7, 2013 | 07:05 PM
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
The Bonnie seats look good! You could always do the rear seat delete if worse came to worse.
Old Jul 7, 2013 | 08:53 PM
Engine: LB9 | LS1
I glanced over the seats in person and did some rough measurements on the seat bottom and seat back... it will be snug but should fit. Only hurdle I see now is the seat frame assembly. Power driver's seat and power lumbar. Passenger seat is manual but also has the power lumbar feature
Old Jul 8, 2013 | 06:36 AM
The_Wraith's Avatar
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Technically you could leave stock grey leather in the rear. Those are easy to get. I can't count how many times I went to the yard and both front seats were taken with the rears still there. Factory dark grey rears will go with any other black/grey seat.
Fast355
Dec 2, 2016 06:33 PM
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
InfinityShade
Aug 22, 2015 08:00 PM
Randomtask2
Aug 21, 2015 10:54 AM
