Stock Gauges won't fit into dash
Old Jul 29, 2013 | 09:41 PM
awildryan's Avatar
Car: 83 Camaro Z28
Engine: 5.7 Vortec 4bbl
Axle/Gears: 3.23 4th gen axle
Hey everyone, I recently bought a 1983 Camaro Z28, I decided to rip the whole interior out to check for any rust that needed to be fixed.
Now that I am finally putting the car back together I can't get the Gauge cluster to fit back into the dash...
When I bought the car they weren't bolted to the dash, just kinda sitting there.
So... Do the V6 and V8 gauges not fit the same? Or is there like a bracket or something I am missing? Thanks in advance...
Old Jul 29, 2013 | 09:58 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Re: Stock Gauges won't fit into dash
All clusters in Camaros from 82-89 are the same as far as I know. There are two studs that the cluster slide over. These two studs protrude through the white square sockets below the gauges where the idiot lights would reside. Look to see if that helps any!
Old Jul 30, 2013 | 09:00 AM
awildryan's Avatar
Car: 83 Camaro Z28
Thanks, but the gauges don't even seem to line up with those studs, theyre just little plastic ones right? But the whole cluster seems like it doesn't really want to fit in the hole.
Old Jul 30, 2013 | 10:07 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
can you post some pics, maybe your missing something that is not obvious? the studs that line up are metal as far as I recall.
Old Jul 30, 2013 | 06:33 PM
awildryan's Avatar
Car: 83 Camaro Z28
Ok sure, all I really have is the main dashboard and the cluster. If the studs are metal, it kinda sounds like I am missing something. Except Ill have to figure out the picture uploading
Old Jul 30, 2013 | 06:35 PM
awildryan's Avatar
Car: 83 Camaro Z28
It helps when you push upload, doesn't it?
Attached Thumbnails Stock Gauges won't fit into dash-img_0604.jpg   Stock Gauges won't fit into dash-img_0605.jpg   Stock Gauges won't fit into dash-img_0606.jpg
Ghettobird52
Jul 5, 2024 11:18 PM
Jeremys87
Jul 14, 2022 09:08 PM
rocn7roc
Sep 21, 2021 02:16 PM
justin57
Aug 20, 2015 07:05 PM
slade5612
Aug 11, 2015 07:19 PM
