rear locking glove box
Old Aug 16, 2013 | 09:44 PM
SuperHawk996xx's Avatar
Car: 1986 Pontiac Trans Am
Engine: 350 cid bore too much to list.
Transmission: 700-R4
OK, so I have been working on my interior painting plastics and my rear locking glove box (the card board one) is falling apart. am I the only one having this problem if so, what have you guys done?
Old Aug 16, 2013 | 11:19 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: rear locking glove box
What is falling apart? The plastic cover or the cardboard box?
Old Aug 17, 2013 | 06:27 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Dime a dozen at the bone yards.
JamesC
Old Aug 17, 2013 | 07:54 AM
Its the cardboard part. I thought about just cutting it off but then things would rattle if I stored them in the rear quarter panel. JamesC, it would seem every one I find in the junk yard is in worst or the same condition as the one I have.
Old Aug 17, 2013 | 02:20 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Can you use your old tattered one as a pattern to make up a new one using art board or similar material?
Old Aug 17, 2013 | 03:19 PM
Firechicken86's Avatar
Car: 1989 Trans am GTA
Transmission: t56 6 speed
Axle/Gears: 3.45
Why not get a reproduction. http://www.classicindustries.com/fir...rts/14599.html
Old Aug 18, 2013 | 08:28 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Originally Posted by Firechicken86
I have one in my car. Fits great.
Old Aug 19, 2013 | 07:37 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
I used the original one as a pattern and made one from sheet metal
Old Aug 19, 2013 | 06:44 PM
camaro_lover92's Avatar
Car: 1991 camaro rs t-top custom paint
Engine: factory 305 v8
Transmission: Standard factory tranny
Axle/Gears: standard factory axle's and gears
^ that sounds like a good idea to me aswell
Old Aug 20, 2013 | 10:04 PM
Rusty, that sounds like an awesome idea! I didnt know you could get them reproduction. Next question..How the hell do you get it off? It looks to me pop riveted on.
Old Aug 30, 2013 | 11:26 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
As I recall there are sheet metal nuts that thread onto plastic studs on the back side of the plastic interior trim panel. You should get the special tool that presses into the sheet metal nut to remove them. Otherwise do your best using s pair of pliers or vise grips.
Lon
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Casey Meyers
Mar 2, 2016 10:46 AM
I'llrocya
Feb 2, 2016 11:43 PM
