Under door lights.
Old Aug 28, 2013 | 12:41 AM
Jared N259's Avatar
Under door lights.
I was looking at doing some under door lights so that when the doors open, the light comes on. I am not talking about what I have seen before where people basically stick an led strip on the bottom of the door and called it good. I mean a light integrated into the bottom of the door. I would prefer if it was in a 4th gen door because that is what I am gonna put in but if it was in a third gen panel that would be fine. Again, I am looking for a fully integrated light that looks like its a factory option.
Old Aug 28, 2013 | 09:15 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: Under door lights.
Called "puddle lights".
I don't know of any kits specific to f bodies, but many newer cars have them. Just a matter of cutting a hole and wiring to the footwell lights, shouldn't be too hard. Put it near the rear of the door or the light will be blocked until the door is open pretty far, we have long, wide doors.
Old Aug 28, 2013 | 01:10 PM
stealtht/a's Avatar
You got me thinking about this and I realized the door gfx would be a great place to put those on our cars as long as they are properly waterproofed .
Old Aug 28, 2013 | 04:05 PM
Jared N259's Avatar
That's kinda what I was thinking. I have had people walk into my door three times now because they can't see how far it sticks out at night. While this is mostly because they are stupid, I thought it would be a nice modern touch to put them in somewhere. I was thinking of buying a led light unit and seeing if I couldn't retrofit it into the car, that would be a relatively easy way to have a sealed unit. I have little experience with electrical work but I think the easiest way to make it turn off and on depending on the position of the door would be a sensor like the one used to turn the cabin done light on and off. I.e. door opens and the dome light + door light turn on. Door closes, they turn off
Old Aug 29, 2013 | 07:19 PM
stealtht/a's Avatar
It would be very easy to splice into the existing harness. There's a light in the footwell, right next to the door sensor. Splice into that then just run through the door wire harness. The footwell light is already controlled by the door switch.
You realize I'm probably going to steal your idea now, right?
Old Aug 29, 2013 | 07:37 PM
firechicken1992's Avatar
Car: 92 Firebird--02 Grand Prix GTP 2Dr
Engine: Poncho 400--3.8 Supercharged
Transmission: T56 6 Speed--4T65EHD
Axle/Gears: Open 10 bolt 3.42--Internal 2.93
ive thought of doing this myself, be interesting to see how this goes. shouldnt be too hard
ive always thought of going to a salvage yard and pull the lens and housing out of a car that already has it and integrate it in
Old Aug 29, 2013 | 10:08 PM
Jared N259's Avatar
Well it will be a long while before I would do this project but it should definitely be interesting. I hear alot of people say, "I have considered doing this" but I haven't heard of anyone who has done it. Stealtht/a, please do! You'll probably be doing if first so you can tell me all the difficulties
Old Aug 30, 2013 | 07:08 PM
86_irocz-28's Avatar
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
thought about doing it that way but didnt reall see a way of doing it without cutting the door plus I had a strip laying around
Old Aug 30, 2013 | 11:10 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
My wife's 90 Volvo 740 has a red light on the end of the door that lights up when the door is opened. I added them to my Camaro too. It was a PITA to do though. Not only did I have to cut the rectangular hole in the door, but fabricate a special bracket to go inside to hold the lamp in place. I did the passenger side door first, then discovered there is a very important sticker that was in that location on the drivers side. Oh well, too late now. I figured symmetry was more important than that sticker. Besides if anyone criticizes the modification, I just have to look at the pink slip to see who ultimately makes the call on what is done to the car.
Lon
Old Aug 30, 2013 | 11:36 PM
Jared N259's Avatar
Lon
Pics?
1Aauto
Sponsored Vendors
Feb 8, 2017 03:09 PM
LC2 TECH
Interior Parts Wanted
Jan 27, 2016 08:38 PM
Eric-86sc
Exterior Parts for Sale
Nov 16, 2015 10:20 AM
383cam
Sep 9, 2015 06:01 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
