another hatch pull down problem (with pic)
Old Sep 11, 2013 | 04:31 PM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
Hatch doesn't pull down/lock closed. Looks like it's already in the down position. So, would this be a bad reverse switch?
And are these things supposed to get filthy? Car was a daily driver for about 14 years...
Old Sep 11, 2013 | 07:17 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: another hatch pull down problem (with pic)
What happens when you turn the key to 'open' it? Does the pull down rise up? It's hard to tell from the pic but it's likely you need new guides. top-downsolutions.com has a set and they worked well for me. Just have to clean it and try it. Key should make it go up and pressing the little switch in opening should make it pull down. At the end of each travel you should hear a distinct click as the reversing switch is flipped.
Old Sep 11, 2013 | 07:47 PM
Car: 1991 Firebird
Key turn will unlatch it, nothing else. A screwdriver in the latch will secure it, but no noise or movement.
Old Sep 13, 2013 | 01:09 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Fuse? Is there power at the motor? Have to start checking the wires etc.
Vintageracer
Jan 10, 2020 05:33 PM
Infested
May 22, 2018 11:56 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
madsv1000
Aug 20, 2015 06:45 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
