Speedo not working
Old Sep 18, 2013 | 11:43 PM
Gregdonna's Avatar
Speedo not working
Hi all i have a 92 Z28 and i replaced the speedo to the 145 and i wanted to know is there a fuse that the speedo works off of. All of the other gauges work but the speedo just reads 35mph like it's stuck there. So if there is a fuse can someone tell me where it is and which one it is thanks.
Old Sep 19, 2013 | 12:08 PM
James Moseley's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Transmission: Th700R4
Axle/Gears: stock
Re: Speedo not working
I have speedo problems myself but haven't swapped anything yet. Still goes through all 4 gears but no speedometer, and before it completely stopped working it was intermittent, when it worked my RPM's would go about 250 RPM less for the same speed.
Old Sep 19, 2013 | 01:22 PM
grngryoutmyway's Avatar
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
Ermm if your old one was working and the new one isn't sounds like a broken speedo. There are all kinds of posts in the electrical section on speedo's though, so search in that section.
Have you driven the car? Sometimes they get a weird reading when sitting and reset after you drive it for a short time.
Jorlain
Aug 24, 2022 05:11 PM
Jeremys87
Jul 14, 2022 09:08 PM
Wade787b
Sep 29, 2015 01:15 PM
Irocohio
Aug 12, 2015 08:03 AM
beachrodder
Aug 7, 2015 04:27 PM
