4thgen ignition lock cylinder swap?
Old Oct 15, 2013 | 07:40 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
About a year ago I replaced my aging ignition lock with a parts store lock. Short story is it sucks. I can start the car without keys and/or pull the keys with the engine running. Total POS. I prefer the locks installed in a 4thgen, they have the lock button (for manual trans cars) and feel much stronger and more solid. Will they fit thirdgens?
Old Apr 20, 2015 | 11:59 PM
wildmon69's Avatar
Car: 86 T/A/1990 Firebird
Engine: 5.3 L33 pt7675 / Ls1
Transmission: 4L80E/T56
Axle/Gears: 3.73/4.10
Re: 4thgen ignition lock cylinder swap?
Did you ever find out if the 4th gen ignition cylinder will work in a thirdgen column?
Old Oct 21, 2015 | 02:46 PM
tglennon11's Avatar
Car: 87 IROC
Axle/Gears: LS1 10bolt w/ 3.73
and ill bump this as well, any answers?
Old Oct 21, 2015 | 04:12 PM
tglennon11's Avatar
Car: 87 IROC
I may have found the answer, looking at Rockauto interchange guide, anything with VATS is interchangeable, so look for ACDELCO D1456C click on the part number it will show that it is good for '89+ camaros and '88+'birds, which leads me to believe the mounting points are the same, its just a VATS issue.
i might be adding this to my list for the winter.
Old Oct 25, 2015 | 10:21 AM
alex722607's Avatar
Car: 1988 Pontiac Transam GTA Notchback
Engine: 2003 Chevy 5.3 Vortec (325 cu)
Ignition locks are the exact same. Lock wise the only thing that changed was the door locks. They went from code D to H. Really what that mean is that the grooves are different.
Old Oct 25, 2015 | 10:16 PM
tglennon11's Avatar
Car: 87 IROC
thanks alex,
any idea if the 4th gen lock cylinder for a manual car will work as a replacement for the lock cylinder and lever in the 3rd gen?
Old Oct 25, 2015 | 11:54 PM
alex722607's Avatar
It should. Ignition locks did not change in firebirds from 89-2002
As far as door locks, I'm not sure, but can't see why not.
Old Oct 26, 2015 | 07:58 AM
tglennon11's Avatar
Car: 87 IROC
great, thanks
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
db057
Aug 22, 2015 08:17 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
