Need to know what dash and console pieces will swap from an '86 to a '91
Car: 1986 Camaro Sport Coupe (Part Out)
Engine: 2.8 MPFI V6
Transmission: 700R4 Automatic 4 speed
Axle/Gears: 3.42 Open With Drum Brakes
Anybody out there know what dash and console pieces will swap from an '86 to a '91? I know the dash face and cluster are different on the '91 and '92 cars anything behind that that will swap? Does the center console swap too? Need to know ASAP.
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: Need to know what dash and console pieces will swap from an '86 to a '91
Dash and gauge cluster are indeed different and more rounder. Behind mounting points are the same.
Centre console is the same. 91 and up had yellow pw, ph buttons compared with white buttons up to 89 but size and fit are the same.
91 radio/ac cover bezel is a bit more rounder than the 86-89 but works fine without issue
Post some pics of the swap when you can....
Engine: 2.8 MPFI V6
1992 Trans Am
May 10, 2023 07:19 PM
ambainb
Apr 25, 2016 09:21 PM
