replacing rear hatch pull-down assembly
Old Nov 5, 2013 | 01:38 AM
kowtownkid's Avatar
Car: 1991
Engine: stock 305
Transmission: 5 speed standard
Axle/Gears: stock
does anyone know if there is a aftermarket stationary latch bracket to replace the motorised unit it came with ? 91 camaro r/s
Old Nov 17, 2013 | 11:31 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: replacing rear hatch pull-down assembly
Yes and no. There were two styles of pull-down unit used in 1991. Early 91 models used a pull-down with a metal frame (where it attaches to the car body). Late 91 they switched to a smaller and much lighter version with a tan-colored plastic frame (where it attaches to the car body). If you have the late 91, then you could get a slam-latch from a late 91-92 convertible. There is no slam-latch made that will fit the earlier style pull-down unit that was used from 1986-early 91. However, that won't stop you from converting yours to a manual slam-latch. I've seen many in the pick-a-part yards that were converted by their owners using drywall screws, baling wire, chewing gum, popsicle sticks, etc.
However as an alternative, you could always repair yours. I sell all the parts to repair these pull-down units.
Lon
Old Jul 27, 2015 | 03:08 AM
Paco131405's Avatar
Do you still repair em'.
Old Jul 27, 2015 | 10:17 AM
lonsal's Avatar
I have you covered any way you wish to get it repaired. I sell the parts along with the instructions so handy car owners can do the repair themselves and save on labor. I have offered to diagnose and repair customers hatch pull-down units. I also sell refurbished hatch pull-down units which include a 1 year warranty.
Lon Salgren
Old Aug 4, 2015 | 06:35 PM
gojoe's Avatar
Car: 91 RS / 91 Z28
Engine: HT383 / Stock TPI 350
Transmission: T-5 / Stock Auto
Axle/Gears: Stock, open / Stock, with True Trac
Wow, I just used a visegrip needle nose plier to trap the travel and had to slam it. Of course I had a spare needle nose plier in case.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
