Let see some after market gauges/ pods.
Old Nov 16, 2013 | 07:33 PM
87irocZ28Crush's Avatar
Car: 1987 Iroc Z28
I'm in the market to do some gauges for my 87 and need to see some ideas. Please name the brand that you have. Ready set go.....
Old Nov 17, 2013 | 01:08 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Let see some after market gauges/ pods.
I posted this a while back in another thread.
Autometer pod, Stewart Warner Heavy Duty gauges, clock and vacuum.
I wanted a clock but felt just the one "gauge" would look kind of weird. I choose the vacuum gauge because it's kind of old school (no one runs them anymore unless there's boost).
I went with a screw-on pod because the full pillar sat tight against the dash pad (no good, IMO). I pitched the supplied plastic push-in fasteners and instead used black oxide button head screws.
Old Nov 18, 2013 | 12:57 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
heres mine while I was building it
Old Nov 18, 2013 | 09:14 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I already have the details of mine here: https://www.thirdgen.org/forums/inte...i-made-my.html
Old Nov 19, 2013 | 10:16 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
That's TMI.
Old Nov 21, 2013 | 06:49 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
i like this pod though i'll probably go with a triple.
Old Nov 21, 2013 | 07:05 PM
anobii's Avatar
Car: 86 Camaro SC
Engine: 5.3L LM7
Transmission: TH350
Just the vitals.
Autometer Z-series tach and speedo.
Autogauge fuel level.
Sunpro mechanical oil pressure and electric water temp.
Old Nov 21, 2013 | 07:11 PM
Car: 1987 Iroc Z28
These all look great. Now I just have to figure out how far I want to take mine.
Old Nov 21, 2013 | 09:54 PM
Jersey89GTA's Avatar
Car: 90 Iroc Vert
Engine: 5.0L
I'm thinking about this overlay for stock gauges ....
Attached Thumbnails Let see some after market gauges/ pods.-gaugecopy.jpg
Old Nov 21, 2013 | 09:57 PM
Car: 1987 Iroc Z28
Where did you find these from? I like the clean look
Keith
Old Nov 22, 2013 | 06:31 PM
Car: 90 Iroc Vert
Engine: 5.0L
Black Cat Customs - I just sent them an EM cause their website only offers 91/92 Camaro ... I think they are the same as my 90 ? Will find out...
http://www.blackcatcustom.com/products.htm
Old Nov 22, 2013 | 07:57 PM
Tibo's Avatar
Car: 1991 Z28 Vert
I used the overlays and they seem to have a short life expectancy. I have also been through three gauge clusters which is why I decided to make my own custom gauge cluster with good gauges. The tachometers went bad and I had a few of the buld sockets start to go. I still have some white face blue glow backgrounds if anyone wants them for free plus shipping.
Old Nov 23, 2013 | 07:17 AM
Car: 90 Iroc Vert
Engine: 5.0L
Tibo please elaborate on the life expectancy issue. Do they peel up, fade, turn funny colors ? I'm interested before I do something.
Old Nov 23, 2013 | 07:35 AM
skinny z's Avatar
Originally Posted by anobii
Just the vitals.
Not to hijack this thread but in both examples above, the turn signal indicators and the high beam indicator have been changed. What's the deal with connecting them to the existing dash wiring? Same with the fuel level gauge. The rest (oil, temp, vacuum, volts) I have figured out as my sensor wiring is all new and separate from the OEM harness.
I'll be doing a custom dash this winter and am collecting information.
Thanks.
Old Nov 23, 2013 | 05:22 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Well, I can't speak for all clusters but 90-92 Camaro you cannot reuse anything. You either use the entire stock cluster or none of it.
Old Nov 23, 2013 | 06:52 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Some great ideas....keep the pics coming.
Old Nov 23, 2013 | 08:18 PM
one92rs's Avatar
Car: SOLD!!!!!
it was for a Mitsubishi evo lower dash. just fitted it under the vents.
Old Nov 23, 2013 | 09:44 PM
Car: 1987 Iroc Z28
Very nice guys. Might have to take a little from each.
Old Nov 23, 2013 | 11:20 PM
Tibo's Avatar
Car: 1991 Z28 Vert
My problems were with the glow overlays. The first set bubbled and caused the needle(s) to temporarily hang up and the second set seemed to develop a short in the overlay causing it to flicker or just not come on. My third set lasted until I did my custom gauge cluster. I had a set of plain white face overlays and as I recall they worked OK.
Old Nov 24, 2013 | 07:56 AM
zenish's Avatar
Engine: 305 tbi
just ordered a triple through amazon for 65 dollars.
Old Nov 24, 2013 | 10:32 AM
Car: 1987 Iroc Z28
I just received my triple from speedhut for 64 shipped. Fits real nice on the pillars. Now I think I'm going to go with glow shift guages. I like these because when they are off there face is black. Anyone use these before?
Attached Thumbnails Let see some after market gauges/ pods.-image.jpg
PurelyPMD
May 5, 2016 04:57 PM
1992Z28!
Nov 19, 2015 07:33 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
