leather shift knob pattern
Old Dec 11, 2013 | 03:23 AM
Barlow8869's Avatar
Car: 1989 IROC-Z / T-Top -1987 GTA
Engine: 305 (LO3) _350 (L98)
Transmission: 700R4 _ 700R4
Axle/Gears: 2.73 L.S. - ???
leather shift **** pattern
anyone know where to find a pattern for a'89 iroc shifter, i have been looking for a few days without any luck
Old Dec 11, 2013 | 02:21 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: leather shift **** pattern
https://www.thirdgen.org/forums/inte...ncy-brake.html
PM this guy,he does beautiful work.
Old Dec 11, 2013 | 06:54 PM
Barlow8869's Avatar
thank you, but i am just looking for the pattern to make my own, wife through out the old cover the one time she cleaned out the car
Old Dec 12, 2013 | 03:41 AM
timberjake's Avatar
Really this guy has many varieties
Old Dec 12, 2013 | 05:38 AM
((Mike))'s Avatar
Car: 1969 RS Z28 X33 Norwood built
Engine: 383 Stroker
Transmission: T10 4 speed
I bought an Ebrake handle and a shifter **** with blue stitching from fierolover and they came out very nice. He is very reasonable too. Even If I knew how to do it myself I would just have him do it. It was that cheap.
Old Dec 12, 2013 | 11:33 AM
mantaguy's Avatar
Engine: 5.0 EFI
Old Dec 12, 2013 | 03:36 PM
Barlow8869's Avatar
i know they dont cost much, but i want to make mine
Old Dec 15, 2013 | 01:27 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
I made my own as well w/ perforated leather.I think i have the OE leather that i used as a template.Can you make a pattern from a post pic?
Old Dec 15, 2013 | 01:35 AM
Barlow8869's Avatar
i think i can, if you could put a ruler or something acrossed the biggest part ... and it should just be a mirror for the other side, so one side should do it ... i sure would thank you if you could do that
Old Dec 15, 2013 | 02:21 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Well, here's what i have.Thought i still had the leather, but it was beat.Made this using the OE piece, its a bit oversized.I used to make mine though.
Old Dec 15, 2013 | 02:41 AM
Barlow8869's Avatar
cool, and that left enough for seams and to tuck the ends in? i am going to do a french seam on my shifter and e brake ... and btw, what shift **** do you have?
i have this shape
http://img.auctiva.com/imgdata/3/4/1...9843804_tp.jpg
Old Dec 15, 2013 | 10:34 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Crap, never even occurred to you may have the later style.Ive got the round one, but i do have the leather e-brake.That one is in good shape.
Old Dec 15, 2013 | 02:59 PM
Barlow8869's Avatar
i thought so, dang it ... i still have the e-brake ... your's sure turned out nice though
Old Dec 15, 2013 | 07:42 PM
ThePain's Avatar
Car: 1992 RS
Transmission: Automatic
That is sooo nice...
Old Dec 15, 2013 | 08:21 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Thanks, Only guy i could find locally wanted $110.So i did it myself.Have you tried just laying a piece of cloth over yours & make a pattern from that?
Old Dec 16, 2013 | 04:11 AM
Barlow8869's Avatar
i am going to give it a try, i have a few bucks coming soon, going to buy a yard of leather and see what happens ... want to try to wrap my dash with all french seams too, just not sure how to get the leather stretched over the dash when it is all sewn
Old Dec 16, 2013 | 08:03 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Are french seams the type hidden behind the fabric? That be tough to do on the dash.I think the foam would bend if you stretch the leather too tight.
When i finished my shifter/e-brk.They were i bit loose.So i ran them under warm water for bout 6-7 min, then patted the excess water out.Let em dry away from heat/sun for a few days.After a week or so, & more so later on, the leather shrunk.Leaving them nice & tight, no wrinkling or warpage.
Old Dec 16, 2013 | 08:05 PM
Barlow8869's Avatar
this is a french seam ... http://s3.amazonaws.com/thmb.inkfrog...9815.jpg/600/0 ... it is not a good one, but you get the picture
Old Dec 16, 2013 | 08:08 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Thats what i started doing on my shifter boot, but gave up left they way it is.
Eric-86sc
Feb 25, 2016 09:02 PM
Night rider327
Feb 25, 2016 09:50 AM
skirocz28
Members Camaros
Nov 12, 2015 07:52 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
J. Chris Davis
Sep 28, 2015 11:55 AM
