No hatch release switch
Old Dec 16, 2013 | 01:46 AM
Chase 89 RS's Avatar
I cant find a hatch release switch inside my 89 camaro RS. Does it not have one or was it removed for some reason?
Old Dec 16, 2013 | 06:36 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: No hatch release switch
It was an option, so sounds like yours doesn't have it.
Old Dec 17, 2013 | 06:46 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
i added one to mine.the solinold bolts on easy and i use my aftermarket door locks remote to release the trunk.[factory door locks]
Old Dec 24, 2013 | 10:54 PM
cwt's Avatar
cwt
Anyone know how much of a pain it would be to wire one up? I have the latch pull down but not the trunk release just the blank button on the dash.
Old Dec 25, 2013 | 12:56 AM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
The hatch release switch is located on the center console in between the power window switches, if you have power windows or not. Its possible the car is already wired for it. The connector for the switch might be there under the panel where the switch would go and the wiring might be there where the pull down latch is at. If not, it really wouldn't be that hard to wire up a hatch release with the factory solenoid on the pull down latch.
tglennon11
Sep 23, 2015 05:30 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
flash2042
Sep 7, 2015 07:15 PM
scottmoyer
Sep 7, 2015 07:06 PM
luvofjah
Sep 3, 2015 07:08 PM
