reverse switch on trunk pull down
Old Dec 28, 2013 | 03:40 PM
aftershock1974's Avatar
Car: 88 IROC
Engine: 5.7 TPI
Where is the reverse switch located on the trunk pull down mechanism?
Old Dec 28, 2013 | 06:09 PM
Blue 90 RS's Avatar
Car: 1990 Camaro RS
Engine: 5.0L
Transmission: WC T5 5-speed
Re: reverse switch on trunk pull down
Just above the motor/gear housing, behind the rod/bolt that pulls the mechanism down. I just rebuilt my pull-down unit in my 1990 RS. Spent $75 on parts from Hawk's, but did not replace the reversing switch. Check it before you buy a replacement. They don't make them anymore, and I could only find used or rebuilt ones. I was going to go ahead and replace it while mine was apart, but since it worked OK and there were no new ones, I decided to leave the existing one in. It's hard to see it when the pull-down unit is intact and installed in the car.
Old Dec 28, 2013 | 06:35 PM
Car: 88 IROC
Engine: 5.7 TPI
Thanks. I just rebuilt mine also. Didn't pay much attention to the switch whem I had it apart. I installed it all back in the car but I get nothing. Nothing moves. Stuck in the down position. Rebuilt it with new motor, new housing, new gear, and new guides. Got power going to it. I just wanted to see if that switch made a difference.
Old Dec 28, 2013 | 06:52 PM
Joe Tag's Avatar
Sometimes the lever in the switch that tells the relay whether the hatch is closed or not breaks off. It's the small switch that screws to the latch mech on top. It would normally be in the up position when that happens, but something to check.
tcarlos13
Interior Parts Wanted
Sep 2, 2015 07:29 PM
Pilotrick50
Sep 2, 2015 12:48 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
mizz0313
Aug 12, 2015 06:45 AM
hokis
Aug 9, 2015 03:57 PM
