clutch pedal removal 86 firebird
Subscribe
Dec 28, 2013 | 03:58 PM
i tried getting up under the clutch yesterday because my car is an auto now i and i wan't to remove it what i am wondering is if you have to take the bottom dash out underneath the steering wheel to remove the clutch pedal i tried feeling up there but i can't seem to find where the bolt would be to take it out pictures would help a lot to
Reply 0
Dec 28, 2013 | 04:22 PM
Re: clutch pedal removal 86 firebird
I went outside and snapped a couple pics (its cold so hope you're appreciative atleast). I already have my whole dash torn out so i couldn't tell you how hard it'd be, my guess is itd suck, the bolt and nut are like either 15mm or 16mm.. There is one bolt that holds the clutch and brake pedal on the same axis. In the first pic the empty bushing is where the clutch pedal sits. there is also two support beams that bolt from the outer ends of the bolt, down to around where the hydraulic cylinder of the clutch pedal meets the firewall (with numbers 1 and 2 correlating to each other). let me know if theres anything else you need, i have my car torn apart so i can run outside and snap any pics xD
clutch pedal removal 86 firebird-1228131508-2.jpg   clutch pedal removal 86 firebird-1228131508a-2.jpg
Reply 0
Dec 28, 2013 | 04:48 PM
thank you very much for the pics and every thing and yea i know its cold out here to i think i might go out in a few minutes and get the 15mm or 16mm socket set and go try to take it out i hope i don't have to take the dash off to get to it. its my first car so still learning my way around it by the way do you know where the passenger mirror adjustment **** is i can't seem to find it
Reply 0
Dec 28, 2013 | 05:11 PM
i dont remember there being a **** for it, i always had my girlfriend adjust it for me by hand from the passenger seat xD. i dont remember what all was in the way of the bolt and nut, you may be able to get to it just by taking the knee pad area off, maybe dropping the steering column down a little bit (only 2 nuts), but all my wiring is gone right now so you may have to fight all that. there's a clip that connects the hydraulic shaft to the pivot point on the pedal, so you'd have to take that off too. my car is going to be an automatic for now because manuals are alot more expensive than a th400, but i want to go back to manual at some point. so for now ill still have to press the clutch pedal down to start it even tho its an automatic......if someone ever tries to steal my car they'll be VERY confused
Reply 0
Subscribe
