85 Trans Am - seat recovering questions
Old Dec 30, 2013 | 09:41 AM
ejscarfo's Avatar
The upholstery of both front seats are shot. Holes in the lower cushion of one and ripped seams on the upper cushion of the other. They need to be recovered or replaced. How easy is it to recover these? I have the cloth interior, no plastic liner on the back part of the upper cushion either if that helps describe the seat. All the videos I've seen show a different type seat than what I have. The bottom may be the same, but the tops are different.
Also, I'd like to add a power seat track on the driver's side. Are these cars max-wired? I'd hate to cut up a harness to get power to a seat. I'd prefer plug-n-play.
Old Dec 30, 2013 | 11:27 AM
jez3941's Avatar
Car: 1984 Trans Am- L69, WS6, J65, W62
Engine: 350 .020 over
Transmission: auto 700R4
Axle/Gears: 4.11 Limited Slip
Re: 85 Trans Am - seat recovering questions
The power seats are easy and just plug and play.
after installing the power track on the seat you cut a small slit in the carpet and run two wires through.
screw the ground to one of the channels that have the seat studs and then run the power wire to under the door sill into the wire channels then forward. It plugs into a block that is behind the kick panel and up a little bit
Old Dec 30, 2013 | 02:44 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Do your seats look like these,if so Classic Ind.has what your looking for.
Old Dec 30, 2013 | 02:48 PM
ejscarfo's Avatar
That's the style, except for color, I have the dark gray inserts in the lighter gray seat (I love the red and gray combo you have). Did you recover yours?
I've requested the Classic Industries catalog to see the color options they have as their website doesn't show much. We want to change the seat color to match the black headliner and other fabric parts that have been recovered in black. We were looking to do gray inserts with black seats.
Old Dec 30, 2013 | 03:21 PM
mantaguy's Avatar
Engine: 5.0 EFI
Yes I recovered them last year,not hard to do,just hard on the hands.85-86 used the Pallax Material with the Graphite inserts.Classics Graphite is a little darker but they'll take a longer time to Fad,I'm very satisfied with them,I highly recommend them.
When you get the catalog,they have what your looking for
Good Luck.
Old Dec 30, 2013 | 03:34 PM
ejscarfo's Avatar
Originally Posted by mantaguy
Yes I recovered them last year,not hard to do,just hard on the hands.85-86 used the Pallax Material with the Graphite inserts.Classics Graphite is a little darker but they'll take a longer time to Fad,I'm very satisfied with them,I highly recommend them. When you get the catalog,they have what your looking for Good Luck.
How do the tops secure? I remember seeing what looks like a zipper.
Old Dec 30, 2013 | 03:48 PM
mantaguy's Avatar
Engine: 5.0 EFI
You mean head rest??
Old Dec 30, 2013 | 04:06 PM
ejscarfo's Avatar
No, sorry. I meant the upper cushion of the seat. I saw what looks like a zipper poking out of the top of the rear seat.
Old Dec 30, 2013 | 05:01 PM
Joe Tag's Avatar
Not a zipper, it's 2 interlocking plastic u shaped channels. Seat bottom is secured with hog rings.
Old Dec 30, 2013 | 07:20 PM
mantaguy's Avatar
Engine: 5.0 EFI
The seat backs have a zipper on the bottom of each of them,along with hog rings.Just unzip and remove the hog rings and slide the backs off,sounds easy,but it's hard on the hands(they are tight fitting)
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
redmaroz
Aug 16, 2015 11:40 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
