I'm starting an interior build for my white GTA. I've had this car for about two years and have had plans for building the interior.
The carpet was toast the seats were faded and the console was warped so I'm starting from scratch with a clean canvas
I wanted to upgrade from the dated 80s feel, yet be different than the typical 4th gen interior upgrade.
So... With that said I'll be building most of my own parts from scratch and using non-factory colors.
I know you said you don't like regular old 4th gen stuff, but you can definitely modify them to fit your car in a unique way. I had these recovered in grey and ebony, and the grey is the exact color of the door panel material so it's a perfect match. Add the embroidery and it's no regular old 4th gen seat swap.
I find it funny that I'm trying to shy away from 4th gen stuff, yet I'm using 01 camaro seats.
It was the only gm seat that not only bolted in, but has the general shape I needed to work with.
Here is one of the backrest inserts in progress.
I used a roll of 4 mil? plastic and some spray can quick adhesive to get the patterns, then drew the lines with a fine sharpie.
The foam I use is special, but the key is to have a high density foam so that the shape isn't crushed when the cover goes on.
Upholstery glue, a grinder, and time.
I'm starting to get sick of only being able to have only one picture per post, is that just the way it is with iPhones?
Well the week before school started up I came down with flu like symptoms. Urgent care said nearly every patient they saw that day came for flu symptoms.
Had a little time this week to get the covers glued and stapled on, all that's left is mounting the cover boards to the back, which will be on by the end of today.
Thanks for all of the complements, I'm really exited to see it finished as well
The pictures really kill the color, almost like the life is sucked out. In real life everything matches to the tee, the carpet is a few shades darker and the headliner is lighter than the color of choice. Right in the sweet spot.
It's been tough to get any progress made on the car since school has kicked back in. Here's a set of door panels I cut out and made clips for this week.
I've been incredibly busy working out the bugs on the rest of the car however I did bend and polished the stainless insert.
The fourth gen dash is a necessity at this point. Not at all permanent. I am debating using a c5 gauge set for the layout.
I will be bringing the thread back as I've got time to work on the car again. Future plans are to cut the tunnel to fit the t56 in better so my 4th gen console will now be "conveniently" unusable. Looks like its time for mdf, foam, a carving knife, grinder, and time.
Nice progress! I do my own interior work too. Just finished the seats and am currently half way through my second door panel. On yours, there's a white line (maybe piping?). How did you do that and can I see a zoomed in shot of that?
I'm even planning to cut them apart again. I didn't like the bolsters and felt they weren't pronounced enough to hold you in while driving and they looked too much like a stock camaro seat.
The car is on the lift so I'll try to take off a panel for you guys.
