92 Camaro Seat Installation?
Old Jan 13, 2014 | 07:42 PM
Xephy's Avatar
Car: 1992 Camaro RS
Transmission: A4
I bought Bride seats and they're universal. The only thing is, can someone send me a link to buy seat brackets for the driver and passenger side? Any brackets will be fine. Also, where would I start, to take the rear seats out? Thanks!!
Old Jan 14, 2014 | 01:53 AM
dreroc-z's Avatar
Re: 92 Camaro Seat Installation?
Your rear seats have a bolt right under the front part of the cushion its a 13MM. For the back part there is 13MM bolt on the bottom right and bottom left corner.
As for the seat brackets:
http://www.summitracing.com/search/p...rder=Ascending
Old Jan 22, 2014 | 12:32 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Be advised that 3rdGen front seat mounting brackets are somewhat unique.
The drivers side & passenger side are NOT interchangeable, in that the front
mounting pads are offset from the slide, toward the vehicle center.
Additionally, the passenger side bracket legs are of different length,
to accomodate the floor pan contour where the cat-converter is located.
IMHO, you'll probably spend as much time making Universal brackets
fit the mounting studs, as finding some (usually dirt cheap) standard
seat tracks.
Good luck, & keep us posted.
Frozer!!!
Jan 19, 2024 04:55 PM
rocn7roc
Sep 21, 2021 02:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
