Instrumental cluster
Old Jan 22, 2014 | 01:20 AM
Ce84q8's Avatar
Car: 1984 Camaro
Engine: V6 2.8
Hey guys
So I tried to pull out the instrumental cluster to switch out a bunch of defective bulbs. 10 screws on the outer and the two clips on the bottom right next to the brake light and his twin brother on the other side. The right side popped off way but the left was stuck in. It felt like it was tugging so I let it go. Any tips to help with the removal? I almost pulled the dash off lol. Kinda frustrated earlier lol. 84 camaro just in case.
Thanks in advance. I appreciate it!
Old Jan 22, 2014 | 06:38 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Instrumental cluster
Did you remove the speedo cable from the rear of the cluster?
JamesC
Old Jan 22, 2014 | 06:54 AM
Ce84q8's Avatar
Car: 1984 Camaro
Engine: V6 2.8
JamesC
I tried. No wiggle room. My fingers won't fit. Unless there's another way
Old Jan 22, 2014 | 07:00 AM
JamesC's Avatar
You'll have to remove the cable from the cluster. Info in the following link may be helpful:
https://www.thirdgen.org/forums/faq-...-fix-pics.html
JamesC
Old Jan 22, 2014 | 11:11 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Try from underneath the dash.
SS-EXPRESS
Sep 28, 2015 09:14 AM
James Sutton
Sep 23, 2015 02:18 PM
James Sutton
Sep 23, 2015 01:56 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
