Slow moving side window
Old Feb 24, 2014 | 06:48 PM
jabusa1's Avatar
Car: 1988 GTA
Engine: Stock 5.7 350 TPI
Transmission: Stock automatic
The passenger electric window moves very slowly (up and down) in my 1988 GTA. Before I go replacing the motor, does anyone know if the motor is the likely cause or how to identify the true cause?
Old Feb 24, 2014 | 07:39 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Slow moving side window
I just replaced a window motor in my sisters 97 Honda Accord and even with the new motor it was slow.
It turned out to be dirt in the channel that the window was sliding in. It was a small motor and could not take the extra lode well.
Old Feb 24, 2014 | 07:57 PM
jabusa1's Avatar
Car: 1988 GTA
Thank you Ron. I saw a YouTube video suggesting putting silicone lubricant on the window side trim rubber. But this was on a car (non Firebird/Camaro) that had a full window frame. Maybe it is something as simple as that.
Old Feb 24, 2014 | 08:33 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
They all are like that,it's normal.
Old Feb 24, 2014 | 09:25 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
There is a tiny hole (service port) above the connector.You cant see it unless the motor is off the door.I sprayed brake cleaner while working the window up/dn.Bend the red straw into an L shape & stick it in the port hole.Speeds up the window real good.How long it last depends on how dirty the inside is.
There's probably alot of gunk in the motor, brk cleaner just softened it up.Most of the brk cleaner pours out the port.So have a rag under it to catch all the ch!t.
Old Feb 25, 2014 | 06:39 PM
jabusa1's Avatar
Car: 1988 GTA
Thanks again Mantaguy. I was concerned the motor would burn out when you least want it to (down).
Old Feb 25, 2014 | 06:40 PM
jabusa1's Avatar
Car: 1988 GTA
Thanks 84 1LE. If I take the door apart and motor off, I'll be prepared for your solution.
Old Feb 25, 2014 | 06:45 PM
mantaguy's Avatar
Engine: 5.0 EFI
Your welcome,but they do need cleaning and lube often.
1992 Trans Am
May 10, 2023 07:19 PM
pfsteichen
Feb 9, 2016 06:59 PM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
novaderrik
Aug 10, 2015 12:44 PM
