which is correct dome light in 1986 iroc
Car: 1986 iroc
I am replacing missing parts in 1986 iroc with t-tops. I need the dome light but dont know what was orginally in there. I know it did not have the full overhead console but unsure if it was just the plain dome light or dome light with the two little map lights in it?? anybody know what was original for that year?? Thanks alot!
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: which is correct dome light in 1986 iroc
Either one was available in 86 for the Firebirds,so I would assume the same go's for the Camaro's.
Car: 85 iroc z
Engine: 355 tpi
Transmission: 7r4
i could be wrong but i belive the one with the map lights was part of the deluxe interior option the one without was the standered interior dome light
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Your wiring will tell you.
If the wiring / bulb socket is still on the roof then look for a small 2-pin connector. ( Orange and a Black wires ) If there is a connector there then it's the Duel map light dome lens,... if there's no small connector than it's a standard dome light.
If your wiring is missing just install the correct matching harness and you can install any dome light you want.
Be advised; Dome light-to-dash wiring changed a couple times from year to year !
mustangman65_79
Aug 11, 2015 03:17 PM
