Threaded rod manual shifter? I'm lost.
Old Mar 5, 2014 | 05:10 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Ok, used to Camaros, not Firebirds, so forgive me if this is a dumb post!
All my cars always had a solid shift rod with a threaded end for the ****.
The 83 Firebird (V6 base model) I just picked up has a cut threaded rod that had a cheesy shift **** on it.
I haven't seen this style shifter... is it normal or did someone do something weird here?
Here's a pic of the standard one I've always come across:
And here's mine!
Old Mar 8, 2014 | 05:32 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Threaded rod manual shifter? I'm lost.
Best guess is that it was the first year for the T-5, so the shifter may have been redesigned afterwards. Or someone swapped it out for some sort of goofy aftermarket piece...
Old Mar 8, 2014 | 09:09 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
84 thru 86 Camaro Berlinetta V6 T5 cars had a T5 shifter that used a bolt thru the middle of the handle similar to that. The bolt was hidden under a 5-speed pattern 'cover' to hold the shifter **** to the shifter.
I don't know about the early birds,... maybe they used something similar in the T5 cars too.
Old Mar 9, 2014 | 07:51 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Have a pic of the shift **** you mean? Haven't seen one of those.
Do the aftermarket shifters for the V8 T5 fit on this? Might as well just upgrade if I'm pulling the thing anyways!
Old Mar 9, 2014 | 10:49 AM
John in RI's Avatar
Sure,.... here's a pic:
I'm pretty sure that all Camaro/Firebird T5 shifters will bolt to any thirdgen T5 case...... not positive - but pretty sure !
Old Mar 9, 2014 | 12:49 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
hmm, bolt thread looks smaller. Now I'm just lost, thought we had that solved!
1992 Trans Am
May 10, 2023 07:19 PM
Ghettobird52
Apr 21, 2020 08:44 PM
neekolzun
Aug 24, 2015 04:59 PM
LT1Formula
Aug 20, 2015 09:36 PM
