Power Seat Trim Panels
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
I need some help with installing these panels,they seem like their not lining up with the holes on the frame,I can't quit figure out where the small Black spacer type thing goes on the side panel.
Any help would be appreciated.
Re: Power Seat Trim Panels
The panel on the far left covers the upper part of the hinge mechanism. Your upholstery should be behind it so it can clip on then attache with the 2 screws. The middle piece covers the lower part and houses your seat controls. The black bracket mounts to the left side of the lower seat toward the front to mount to the screw hole at the front of that piece. i can't tell what the far right piece is. Also, your switch wiring should run between the seat bottom and the rails, not underneath the rails.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
