floor pan question
Old Mar 26, 2014 | 09:24 AM
scarbucket's Avatar
Car: 1987 Firebird Formula
Engine: 355
Transmission: Borg Warner 5 spd
Axle/Gears: 3:43
floor pan question
I have a few small holes in my pans I was wondering what gauge steel they are so I can put some patchpanals in they aren't enough to replace the pans just like little ones the size of quarters.
Old Mar 26, 2014 | 09:16 PM
scarbucket's Avatar
Engine: 355
Axle/Gears: 3:43
Bump
Old Mar 27, 2014 | 07:23 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: floor pan question
I used 18 ga on the quarters, should be correct for floors too.
Old Mar 27, 2014 | 08:22 PM
scarbucket's Avatar
Engine: 355
Axle/Gears: 3:43
Ok will that work to patch the dense wells
Old Mar 28, 2014 | 06:44 AM
stealtht/a's Avatar
You mean fender wells?
I think so. As far as I can tell, all the body is made from something near 18 gu. I don't think it's exactly 18 gu. When I tried to measure it, it appeared to be close, but slightly thinner than 18, but thicker than 20. I haven't measured it all over, but it looks the same everywhere, they just used more layers in some places. I have only done welding patches on the quarters so that's the only place I've tried. I tried to research what guage the body is made out of but didn't find any definitive answers. All the general info I found on quater panel welding said use 18 gu, cold rolled.
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
redmaroz
Aug 16, 2015 11:40 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Amillionoh7
Aug 7, 2015 01:24 PM
