Shift knob switch
Old Apr 11, 2014 | 11:45 PM
Ce84q8's Avatar
Car: 1984 Camaro
Engine: V6 2.8
Shift **** switch
Mine is cracked down the side. I'm ok with it but would like to swap it out with a pistol grip. I have an auto.,. Unfortunately. And li couldn't fine the screws on the bottom to remove it.
Any suggestions?
Old Apr 13, 2014 | 08:46 AM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Re: Shift **** switch
The auto shifter know is held on by a U shaped wire, that looks like a heavy duty staple. Look at the front of the **** for a horizontal slot. Dig in there with a small screwdriver, and you should be able to pry out that clip. Then the **** just pulls straight up.
Old Apr 13, 2014 | 10:24 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
I'd like to add that if it's the round style **** you need to pull up on the center button and remove the C-clip inside.
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
luvofjah
Sep 3, 2015 07:08 PM
85Special
Sep 3, 2015 04:21 PM
tonys91rs
Sep 2, 2015 07:07 PM
