Gauge Panel Material Question
Old May 9, 2014 | 08:25 AM
skinny z's Avatar
I've searched through almost all of the threads regarding this and haven't come up with a consensus opinion on what works the best.
So I'll ask the question: When making a custom gauge cluster for a Camaro, what is the material of choice?
Aluminum?
ABS plastic?
Plywood?
Something else?
What thickness?
Thanks in advance.
Old May 9, 2014 | 07:42 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Gauge Panel Material Question
I'd say aluminum of around 1/8" thick:easy to work with,thick enough for decent rigidity and a variety of finishes can be applied-painted,black crackle,grained vinyl,"engine turned" ETC...
Old May 9, 2014 | 09:17 PM
skinny z's Avatar
I like the idea of aluminum as a back plane material for all of the reasons you've mentioned. The only reason I'd go for ABS is the that it's available in black and is even easier to work with than aluminum. The problem is that it's not UV stabilized and after a number of years will become very brittle.
Old May 10, 2014 | 07:30 AM
kmcn47's Avatar
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
nothing wrong with plastic, i mean its what the factory made them from
Old May 10, 2014 | 10:11 AM
skinny z's Avatar
I'm pretty sure the factory makes their plastics out of a material that would stand up to sunlight and heat. Otherwise their dash panels and whatever would be in pieces after a number of years. I've worked on injection molding machines for many years and the raw product they start with has a strict specification. Same for the loom tubing we put under the hoods. Not all products are created equeal. The cheap stuff isn't heat stabilized and tends to fall apart after a couple of seasons.
Old May 10, 2014 | 08:16 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
6six6 did his gauge panel from ABS textured plastic.
http://www.ebay.ca/itm/271096102311?...84.m1423.l2649
Old May 10, 2014 | 10:17 PM
T/Aperformance's Avatar
Car: 1987 Trans Am
Engine: 355 tpi
Transmission: 5 speed
Why not use real carbon fiber. Just lay up 3 to 4 sheets on a piece of glass, saturate with epoxy resin , don't use a lot of resin just enough to wet it out, Once is sets up peal it off the class, You should have a nice smooth surface and you can cut out the holes the size you want for gauges and signal lights and mounting screws. I think it would look real nice.
Old May 17, 2014 | 07:06 AM
skinny z's Avatar
That's an interesting thought. I've never worked with carbon fiber although from what I've seen it's seems reasonable to work with.
Old May 17, 2014 | 08:15 AM
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
I'd just use abs. Aluminum may stand out too much unless you paint it black (unless you're going for that look). Rather than go for all that extra work, I'd just use ABS plastic. Plus it's cheap. You can afford to mess up a few times lol
Carbon fiber would be neat. This inspires me to fire up the youtube machine to see how the process goes. It's probably similar to fiberglass..
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
