89 cable speedometer
Old May 25, 2014 | 12:03 AM
Camaro4388's Avatar
Ok ive read through just about every post on the topic and im lost. I am on my second 115 mph speedo and this one is starting to get bouncy and lose reading at speed over 65. My old one started making a grinding sound and stopped reading all together. Anyways the cable driven speedos can they be swapped for a higher one for example a 145 cable from a 86 - 89, without changing other parts. I mean just the Speedo not the cluster. Or do I need to change the gear in the trans ect and so on. Any info will be greatly appreciated.
Old May 25, 2014 | 06:23 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 89 cable speedometer
Welcome to TGO, Camaro.
Check the following link for cable-driven speedo issues:
https://www.thirdgen.org/forums/inte...eedo-woes.html
Unless changes have been made to the car, say a different geared rear, you can simply swap speedo heads.
JamesC
Old May 25, 2014 | 06:31 AM
Camaro4388's Avatar
Nah I haven't done any gear changes to her. Thanks for answering I was lost l. The 145s are alot easier to find than the 115s. I can get a refurbished 145 then I don't have to worry about it breaking again. Right now I cant house around without having it freak out and im worried about It breaking like the last one did
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
