Steering wheel lock
Old Jun 1, 2014 | 07:40 PM
Nighthawkf-117's Avatar
Car: 91' Camaro RS
Engine: 305 TBI V8
Transmission: 700/R4
Axle/Gears: Stock
Steering wheel lock
Hey guys,
I will be completely bypassing the key on my steering column. This isn't a daily driver. I know about all the things I need to do except how to deal with the steering wheel lock. Does the steering wheel only unlock by turning the key? Or does it unlock electrically.?
Old Jun 1, 2014 | 09:08 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Re: Steering wheel lock
It is mechanically operated only, so you can just pull the lock bolt out. Leave the lock plate, because this holds together several parts of your column.
Old Jun 1, 2014 | 09:18 PM
Lurbie's Avatar
Car: 89 Camaro
Found this column repair article that might help with taking it apart.
Car Craft
Here's a pic of the bolt (or pin) that I'm talking about.
Old Jun 1, 2014 | 09:33 PM
Car: 91' Camaro RS
Engine: 305 TBI V8
Axle/Gears: Stock
Ok that helps. Anyone know what the reason behind locking the steering wheel is anyway?
Old Jun 1, 2014 | 10:33 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
My dad always said it was so someone couldn't just roll your car away. That being said the wheel in about every late model car I've owned since my camaro hasn't locked at all lol!
Old Jun 2, 2014 | 12:34 PM
Lurbie's Avatar
Car: 89 Camaro
It was done to meet FMVSS requirements for vehicle Anti-Theft measures. The reason many columns no longer lock is due to increased complexity of other anti-theft measures that prevent you from starting the car.
So I guess I should add a disclaimer to my previous post, that if you take it out and your car gets stolen, it's not my fault.
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
wild1
Aug 27, 2015 09:01 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
