gauges.
Old Jul 3, 2014 | 11:29 AM
happyhapka's Avatar
Car: 1986 Trans AM WS6
Engine: 383 Vortec TPI, PUTS SMILES ON FACE
Transmission: PATC LVL 3 Raptor Transmission
Axle/Gears: 3.27 POSI 9 BOLT
gauges.
So I picked up a 3 pillar pod but would like to know other than AFR what are the other BEST guages I should put in it.
Thanks everyone
Old Jul 3, 2014 | 11:41 AM
Caveman305's Avatar
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
Re: gauges.
Thanks everyone
Depends, are you all stock?
what motor and trans combo do you have
many many options to choose from, just depends on what information you want to be looking at while driving
most people with stock motors tend to just stick with a vac gauge and coolant temp gauge if they are using an AFR gauge to fill the third hole
im still undecided on what to fill one up with in my car, one will definitely be a fuel pressure gauge though
Old Jul 3, 2014 | 11:42 AM
Caveman305's Avatar
Engine: L03, LB9
Re: gauges.
you can also buy a blank plug to fill unused holes until you can save up for the gauge you want, or figure out which one you want
Old Jul 3, 2014 | 11:53 AM
happyhapka's Avatar
Re: gauges.
I was thinking Afr and tranny temp.... I'm not all stock engine wise but my tranny is a lvl 3 700r4 Raptor from patc..... What would I need the vacuum for just curious?
Old Jul 3, 2014 | 01:10 PM
Caveman305's Avatar
Engine: L03, LB9
Re: gauges.
vac gauge would help diagnose a leak or verify you are pulling enough vac for brakes and what not
Old Jul 3, 2014 | 01:30 PM
happyhapka's Avatar
Re: gauges.
OK cool.... What is the vac usually at.
Old Jul 3, 2014 | 02:18 PM
Caveman305's Avatar
Engine: L03, LB9
Re: gauges.
somewhere around 18-21 is typical
Old Jul 3, 2014 | 05:01 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: gauges.
Clock is another idea.
Old Jul 10, 2014 | 07:51 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: gauges.
If you do automotive sports an oil temp is nice to have. AFR gauge is a waste unless you get a wideband O2 sensor. Even then it would only be useful if you have a carb or will tune EFI. Narrow band O2 is inaccurate as you get more and more away from 14.7:1 AFR. You could buy some red leds and make a shift light in one of them. You could also mount a switch or button if you didn't want to drill/cut holes in your stock dash. Could even put a usb or other power outlet there.
Old Jul 11, 2014 | 02:47 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: gauges.
I went with a clock and a vacuum gauge. I chose these two because I lost the clock when I swapped the factory radio.
Vacuum gauge because it wasn't a duplicate of an existing gauge.
Lousy focus...
The vacuum gauge wasn't hooked up for a long time until the last time I had the plenum removed.
Both gauges are Stewart Warner Heavy Duty series gauges.
Ray87Z
Jul 8, 2012 12:13 AM
84Camaro305
Feb 8, 2002 10:48 AM
bluegrassz
Jan 30, 2002 09:32 AM
Chester Cheetah-mobile
Aug 31, 2001 12:19 AM
Desert86Roc
Jul 7, 2001 12:51 AM
