Ashtray filler panel for switches
Car: '87 Trans Am
Engine: 5.0L-V8
Axle/Gears: 3.23 - Posi -10 Bolt
Where can I get one of these? I got manual console just like this for my car, I have been searching on here, I found this picture in a thread from 2005, rather than bumping it, I decided to make a new one.
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Re: Ashtray filler panel for switches
You could use something like this http://www.nitrousoutlet.com/nitrous...automatic.html
Or you can use some plexiglass and dremle out the propor size hole you may need.
Or follow this link... https://www.thirdgen.org/forums/inte...s-4th-gen.html
Enjoy.
Enjoy.
Car: 1992 z28, 2004 F250 6.0
Engine: Ls1
Transmission: m6
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
I have a thread on the fabrication subforum named "another ashtray switch panel". I used a piece of plexiglass and low profile rocker switches to make it and it fits under the stock flip lid. Ill hop on the computer in a little while and post up the link for you.
Car: '87 Trans Am
Engine: 5.0L-V8
Awesome, thank you so much. I am using the two stock power window buttons and will put them in this location. Trying to figure up a neat way to wire up two military toggle switches though somewhere else. Once for the fan, and the other, not sure yet.
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
if you are looking for switches check out these guys and they will look better than a millitary switch. http://www.otrattw.com/
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
