What button/knob is this?
Old Aug 8, 2014 | 06:09 PM
topj's Avatar
Car: 88 Camaro IROCZ Convertible
Engine: 305 tbi
Transmission: auto
What button/**** is this?
Always wondered what that **** is for, i got a 88 vert but not sure if the cluster dash is original
Attached Thumbnails What button/knob is this?-image-286676913.jpg
Old Aug 8, 2014 | 06:35 PM
NowhereFast's Avatar
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
Re: What button/**** is this?
It isn't original. You'll have to figure it out.
Old Aug 9, 2014 | 07:52 AM
Wife'sCar's Avatar
Car: 91 Camaro RS T-Top
Engine: 5.0 Tbi
Press it....... You know you want too....... Do it........
Seriously though see if you can look up under the dash and trace any wires going to it.
Old Aug 9, 2014 | 10:22 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
You can use a Torx t-15 to pull the panel and see what color the wires are behind it. The defrost is usually in that spot.
Old Aug 9, 2014 | 11:45 AM
topj's Avatar
Engine: 305 tbi
Transmission: auto
hmmm yea i think ill check cause theres no rear defrost on a vert so .. lol iv pushed it and pulled the **** out and everything nothing seems to happen im thinkin bout using it for interror led lighting
Old Aug 29, 2014 | 08:39 PM
maule6's Avatar
Car: 92 RS Camaro T-Top
Engine: 305 V8
Transmission: 5 speed manual
Axle/Gears: stock
My guess is they were trying to install a starter button in the car. try putting the key to the run position and push it.
Old Aug 29, 2014 | 08:42 PM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
IT'S THE EJECT BUTTON BATMAN!!!!
Old Aug 29, 2014 | 08:47 PM
nhgator's Avatar
Car: 1985 T/A
Attached Thumbnails What button/knob is this?-rome-meme-generator-ejecto
Old Aug 29, 2014 | 08:55 PM
Joe Tag's Avatar
Old Aug 29, 2014 | 09:48 PM
tyeo098's Avatar
Car: 88 Chimera
Engine: 1994 LO5 5.7L
Axle/Gears: 2.73...?
This thread is almost a month old and no one has pushed the button yet?
Old Aug 30, 2014 | 02:10 PM
rdsxfn524's Avatar
Originally Posted by nhgator
i was gonna say that lmfao
Old Sep 6, 2014 | 08:31 PM
topj's Avatar
Engine: 305 tbi
Transmission: auto
Lolol it wasnt hooked up so who knows i switched it out and put a rocker switch for interrior led lighting
