autometer gauges
Old Aug 12, 2014 | 11:53 AM
MSRed91Camaro's Avatar
Car: I have a 91 Camaro RS
Engine: 383 stroker
Transmission: Stock automatic 700r4
Axle/Gears: I have 3.73 Gears with a Eaton posi
autometer gauges
Hi I am wanting to instal auto meter gauges in my 91 camaro I have switched over to a barbed 383.Does anyone know if I'll need electric or mechanical speedo and teach or will either work thanks for the help.
Old Aug 12, 2014 | 12:12 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: autometer gauges
91 would have an electric speedo
Old Aug 12, 2014 | 08:59 PM
WTR388's Avatar
Car: 87 Trans Am
Tach will also be electric. Should be a white wire in the stock cluster harness in the dash that is for the Tach. Confirm it with a multimeter
Old Aug 12, 2014 | 10:00 PM
Engine: 383 stroker
So it is as simple as taping into stock wireing? Currently my tack is way off and my speedo stopped working
Old Aug 13, 2014 | 12:30 AM
WTR388's Avatar
Car: 87 Trans Am
In general theory, yes it's that simple.
You'll then have to switch it on the tach what mode it's in to read the proper rpm. I couldn't tell you what Setting it would be in, but it is likely on their website. You may also need to put in a resistor from a switched +12v source to the input signal for the tach so it is able to read the signal (more strength)
Speedo I couldn't tell ya.
I went with speedhut gauges, they are awesome for the price (better than autometer). They have a gps speedo that people love. They are very shallow mounting as well. Their customer service is also top notch.
You also customize your gauges as you order them, you choose colors, needle style, font style, trim ring style, add custom graphics etc.
I'll continue to use them for any future needs.
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
