Steering column pivot pins - preventative fix
Old Sep 6, 2014 | 09:47 PM
MN91TA's Avatar
Just did a column rebuild myself (using the writeup and pics from here and here) and thought I'd post a few things. I decided that in addition to fixing the problem, I wanted to prevent the pins from ever loosening again. So I picked up a 4" stainless hose clamp and wrapped it around the column over the pins, right up against the shoulder on the column:
I had to cut a slot in the upper column cover to clear the "head" of the clamp, and trim some plastic inside of the turn signal housing piece to fit over the band. It took a bit of finagling to squeeze it all on over the clamp, but in the end it went on without too much of a fight. Here's how it looks now:
You'd never notice it unless you were looking for it, and I'm pretty sure it will never loosen up again!
Old Sep 6, 2014 | 11:44 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
Re: Steering column pivot pins - preventative fix
Until you slide in or out of the car and it rips your legs open.
Old Sep 8, 2014 | 09:11 PM
MN91TA's Avatar
That's why I always wear a good pair of leather driving chaps.
Jorlain
Aug 24, 2022 05:11 PM
Out-Cast
Mar 22, 2019 09:39 PM
Oenone
Aug 29, 2015 07:54 PM
Out-Cast
Aug 23, 2015 06:33 AM
Bull86
Aug 10, 2015 05:43 PM
