Entire Dash Removal
Old Sep 14, 2014 | 03:18 PM
Simon Wu's Avatar
Car: 1992 Chevrolet Camaro RS
Transmission: Manual
Entire Dash Removal
Hello! I'm trying to remove the dash, the entire piece, to clean out the AC unit and tighten some rattles. As I am taking it apart, I noticed it's missing a lot of screws here and there, and also there is a lot of cut wires with no end, which means the previous owner(s) did some sloppy repair work.
I'm up to the point where the entire dash is loose, but I'm not really sure how many wires are in the back and in which area. Towards the passenger side there are some wire clusters that could be removed with simple clip/pressure style connectors. But I'm not sure what's going on behind the center or passenger side and I don't want to rip anything apart.
Any help will be much appreciated. Thanks!
Old Sep 16, 2014 | 02:31 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: Entire Dash Removal
check out my build (link in my sig).
I have some pics where I swapped out my dash and redid the dash wiring.
Vintageracer
Jan 10, 2020 05:33 PM
toones
Jan 6, 2016 06:00 PM
Street Lethal
Aug 14, 2015 08:25 PM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Aug 8, 2015 07:09 PM
