Heating/AC Blend Doors
Old Oct 7, 2014 | 08:46 AM
ERockZab's Avatar
Car: 1992 Camaro RS
Engine: currently 305 TBI
Transmission: TH200C
Axle/Gears: stock 2.73
Hey everyone,
I'm currently in the process of a complete rebuild and right now I'm just looking ahead for parts that I'll need while I strip the car. I want to keep A/C because it gets hot in Kansas and T-Tops just aren't sufficient for cooling after work... so I am trying to find parts to rebuild the "Heater Box"... is that what its called?
I have been trying to looking everywhere for either replacement blend doors, because the foam is gone and the doors are rusted and moldy. Or even a complete Heater Box that goes under the dash.
I have the shop manual for my 92 Camaro, but its not any help in finding parts... I've scoured it for what might be alternate part names, but no luck.
Can anyone point me in the right direction? Thanks
File Type: pdf
File Type: pdf
Old Oct 7, 2014 | 10:29 AM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
Re: Heating/AC Blend Doors
i have a whole dash. i can look to see whats still attached if that helps. its out of the car
Old Oct 7, 2014 | 10:45 AM
nosajwols's Avatar
Car: 82 Z28
Transmission: TH350 for now
I cleaned mine up (stripped old foam, rust, mold, mouse droppings...), repainted them and used stick on foam weatherstrip to replace the foam. Worked good.
Unless someone has some NOS items anything you find will likely be in similar shape.
Old Oct 7, 2014 | 01:15 PM
ERockZab's Avatar
Car: 1992 Camaro RS
I didn't think about using foam weatherstripping to replace the foam. I actually have some of that on hand from when I fixed my toolbox, so I might just go that route.
Everything worked when I took it out of the car and its still together so that sounds like the best plan.
Thank you very much!
Old Oct 7, 2014 | 01:19 PM
jazzdadss's Avatar
Car: 1989 IROC LSX
Engine: Swapped LS6 Forged by LME
Transmission: 4L65E
I have looked for a re-seal kit for the under dash A/C box to no avail... nothing. 3M foam strips it will be.
Old Oct 7, 2014 | 01:33 PM
ERockZab's Avatar
Car: 1992 Camaro RS
I actually just found a breakdown of the assembly by following a link in another thread (https://www.thirdgen.org/forums/inte...-assembly.html) and it has part numbers and everything listed... all of which are discontinued
The blend doors are actually called "Flaps" (really technical term) or "Valves"... which is why a search for 92 Camaro Blend Door resulted in crap.
Just thought I'd post in case it helped anyone else
http://www.turbotransam.com/JanLarss...ember_1992.pdf
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
kkirch15
Sep 30, 2015 04:44 PM
