89 Camaro door lock won't turn
Old Dec 28, 2014 | 01:21 PM
1985Camaro2.8's Avatar
Car: 1989 Camaro IROC-Z
Engine: 5.7 L98 350
Transmission: Automatic
In my 1989 Iroc, the passenger door lock refuses to turn. The automatic locks do work but neither those, the key, or the manual switch inside the car will lock the door. Its like the lock is frozen. Please Help!
Old Dec 28, 2014 | 01:53 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: 89 Camaro door lock won't turn
Spray some WD40 in the key hole and try moving it without breaking the key.
Old Dec 30, 2014 | 09:47 AM
padak's Avatar
Car: '87 Trans Am
Engine: 5.0L-V8
Axle/Gears: 3.23 - Posi -10 Bolt
If I read it correctly, I dunno if that will help. Sounds like he can press the power lock, and it "locks" but the door doesn't lock. Is that correct ?
Old Jan 3, 2015 | 05:33 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
I'd guess the lock has been changed or the whole door] so you now have the wrong key.
Old Jan 23, 2015 | 09:43 AM
Engine: 5.7 L98 350
After a lot of research, I just decided to take the door panel off and see what was up. The previous owner had stuck some sort of VERY STICKY insulation on the lock rod and it was completly prohibiting it from moving at all. Power door locks are still super weak but im guessing that'll be another pain in the you know what. Haha Thanks for the tips!
Old Jan 23, 2015 | 12:30 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
unbelievable....
89 Camaro door lock won't turn-bill-cosby-annoyed-shaking
Old Jan 24, 2015 | 08:31 AM
TkernIROC1986's Avatar
Car: 1986 IROC-Z
Engine: 5.7L TPI L98 350
Transmission: 700R4 Auto
Axle/Gears: 10-Bolt Posi Disc 3.73s
Do NOT put WD40 in your door locks!!! Being the professional locksmith that I am, I can tell you from experience that that is a HORRIBLE idea! When WD40 drys, it becomes tacky. Then that causes every speck of dirt to stick to the inside over time only binding your lock worse! Take the lock out, take it to your local locksmith, and they can take it apart and service it. If they have the right springs and wafers for the lock, I would have them replaced as well to work with your existing key. We do this kind of thing all the time at my shop. It's very inexpensive if you can take the lock out and bring it in yourself. Also, use a Teflon based lubricant in the future in your locks. It works much better! I recommend a product called Tri-Flow. I use that stuff on a regular basis.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
armybyrd
Dec 5, 2015 09:22 AM
BrianI
Aug 9, 2015 11:52 AM
