Gauges don't work
Old Feb 4, 2015 | 11:12 AM
Drivewaymec's Avatar
Gauges don't work
Hi everyone I got a 91 camaro rs 3.1 v6. I just got it running after replacing the timing chain and gears. The gauges don't work. I replaced the ignition coil which works the tachometer. The tachometer doesn't work, the oil pressure gauge doesn't work the oil temp gauge doesn't work. I find it kinda odd that non of them work. I'm suspecting a wiring problem. I want to know what's the likely cause for this prolbem? Should I replace the oil pressure sender or get the multi meter out and start testing the wiring? Or Is there a fuse or something I missed? I don't know where to start.
Old Feb 4, 2015 | 11:18 AM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Re: Gauges don't work
There's a gauges fuse in the fuse panel above your feet on the drivers side, check that first.
Old Feb 5, 2015 | 09:21 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
http://www.austinthirdgen.org/mkport...uges_part3.gif
http://www.austinthirdgen.org/mkport...uges_part5.gif
Ghettobird52
Jul 5, 2024 11:18 PM
armybyrd
Dec 5, 2015 09:22 AM
Reddeath210
Oct 6, 2015 08:20 AM
Wade787b
Sep 29, 2015 01:15 PM
justin57
Aug 20, 2015 07:05 PM
