Dash Lights
Old Apr 1, 2015 | 11:51 AM
Camaro_383's Avatar
Car: 92 25th Anniversary RS
Engine: 5.0 TBI 305
Dash Lights
For the dash lights in my 92 Camaro RS, when I pull the switch for the lights, none of my lights for my gauges light up or even the backlight for the radio. Now I've done some research and based on the symptoms, my guess would be that it is the dimmer switch that is faulty.
If it helps any, some nights I can turn on my car and the lights and the dash will light up but after riding for a while, they go out.
So basically, what would be my best bet on fixing it? Whether it be as simple as a fuse or just to go ahead and replace the switch?
Old Apr 2, 2015 | 08:35 AM
Caveman305's Avatar
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
Re: Dash Lights
if your fuse was bad the lights would never work, you either have a bad switch, its dirty, or you have a bad wire somewhere
i would buy some electronic cleaner, take the headlight switch out, spray it with the cleaner and turn the ****, the switch is a simple pull/push(on/off) style switch with a potentiometer that controls brightness, if the potentiometer part is worn or dirty your dash lights arent going to function correctly
if cleaning it doesnt work then replace it
Old Apr 2, 2015 | 09:15 AM
Camaro_383's Avatar
Engine: 5.0 TBI 305
Re: Dash Lights
Thank you for this info. I'll try this the next chance I get which is probably this weekend lol.
Pilotrick50
Sep 2, 2015 12:48 PM
stalkier
Aug 13, 2015 12:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
apie2546
Aug 8, 2015 07:12 AM
