Automatic shifter rebuild
Old Apr 10, 2015 | 12:31 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Can the shifter ***** for an automatic be rebuilt? My button is getting sticky and doesn't always come all the way back out. I have to pull on the button for the car to allow me to get it into Park. I saw a shifter spring available on Modern Day Muscle, but I'm not sure if that spring is from the handle or from down in the shifter itself.
Old Apr 12, 2015 | 07:21 PM
Re: Automatic shifter rebuild
Figured it out. Once removed, you can see another staple under the button hat can be pulled out. The button then slides right out. My spring was broken. Easy fix. Modern Day Muscle has them in stock for $2.
Old Apr 13, 2015 | 08:06 PM
Does anybody have the part number for that spring inside the automatic shifter ****? For whatever reason, MDM's website is not working for me and I can't seem to find that spring anywhere else.
Old Apr 13, 2015 | 09:17 PM
alex722607's Avatar
Car: 1988 Pontiac Transam GTA Notchback
Engine: 2003 Chevy 5.3 Vortec (325 cu)
I rebuilt mine last year, none of the pieces were broken though.
May I suggest you look for the spring in another handle. Cause even if you stick a spring in there, if its not the right one, you'll have a problem at an inconvenient time.
Old Apr 14, 2015 | 07:05 PM
Don't want to use used parts which is why I was asking if there was a GM part number.
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
jer4251
Sep 27, 2015 09:52 PM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
MarineIROC
Southern California Area
Sep 16, 2015 05:40 PM
armybyrd
Sep 16, 2015 10:03 AM
