door handle replacement.
Old Apr 21, 2015 | 08:57 PM
DARKmj16's Avatar
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
how hard is it to replace the door handle? i went to open my door and instead of the handle opening it it just broke off. so now i have to roll my window down to get out. so how hard is it to replace it? and if any one has them for sell shot me a price.
Old Apr 21, 2015 | 09:05 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: door handle replacement.
Originally Posted by DARKmj16
....so how hard is it to replace it? and if any one has them for sell shot me a price.
Not difficult. Note the diagram. Many places sells them including Modern Day:
http://www.moderndaymuscle.com/home
JamesC
Attached Thumbnails door handle replacement.-screen-shot-2015-04
Old Apr 22, 2015 | 08:22 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
You could go to your local big box parts store like Pep Boys/Autozone etc.
Look in the HELP/Dorman section. They have them there for around $25 bucks.
Easy DIY install!
http://www.pepboys.com/product/details/9514511/00162
Old Apr 22, 2015 | 08:35 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Same thing happened to me. The interior handle assembly is available, just do a internet search and they are not that expensive. Installation is strait forward.
Old Apr 22, 2015 | 08:43 AM
MSgt Luttrell's Avatar
Car: 1986 IROC Z28
Engine: Carburated small block 454
Transmission: Level 3 Raptor 700R4 2600 stall
Axle/Gears: Strange S60 3:73 S Trac Posi
I just rebuilt both doors on my IROC and changing the door handles isn't too bad of a job, but if you have big hands and forearms like me, you are going to find every sharp object in there while doing it; just keep a band aid or two on hand when you do it.
Old Apr 22, 2015 | 10:49 PM
DARKmj16's Avatar
Engine: 305 tbi
thanks guys. umm that diagram is for the outside handle, i have to fix the inside one lol. but it does look easy so should be ok.
Old Apr 22, 2015 | 11:59 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Watch the torx bolts on the door panel, not all are actual screws and they look like crap after the plastic is stripped out.
You'll need a t-15, a long shaft T-30 (iirc), and a door panel separator may help.
Roll down the window part way, put upward pressure on the door panel to affect the upper rail, and then lightly smack the upper rail inward to release. The upper rails are typically brittle so be careful.
Edit: You may be able to replace it without pulling the door panel but the info is there if you need it.
Old Apr 23, 2015 | 07:28 AM
JamesC's Avatar
Since you didn't mention whether the handle was inside or outside....
JamesC
Old Apr 23, 2015 | 02:33 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I've got a few of these things,...... send me a PM if you still need 1.
Old Apr 26, 2015 | 08:18 PM
DARKmj16's Avatar
Engine: 305 tbi
thanks Scorpner, and sry Jamesc thought i did, thanks though. PM sent buddy
Old Apr 26, 2015 | 10:00 PM
Catheran's Avatar
Replaced both on the 88, fairly easy, might want to consider replacing the door weather strip at the same time if yours needs it, as it required taking off the door panel also.
LC2 TECH
Interior Parts Wanted
Jan 27, 2016 08:38 PM
IROCZDAVE (88-L98)
Sep 17, 2015 07:43 AM
scottmoyer
Sep 7, 2015 07:06 PM
mrdevontay
Sep 2, 2015 08:04 PM
SlowAZ28
Sep 2, 2015 05:19 AM
