ABS Headliner recover?
Old May 1, 2015 | 05:14 PM
87350gtanj's Avatar
Car: 88 GTA Notch/01'WS-6 VERT
Engine: 5.0 LB-9/5.7 LS-1
Transmission: 700R-4/4L60
Axle/Gears: borg warner 3.27's
Hi, just wondering if anyone has ever recovered an ABS style headliner and did u need any special glue other then basic headliner glue?
Old May 1, 2015 | 05:40 PM
TkernIROC1986's Avatar
Car: 1986 IROC-Z
Engine: 5.7L TPI L98 350
Transmission: 700R4 Auto
Axle/Gears: 10-Bolt Posi Disc 3.73s
Re: ABS Headliner recover?
Mine came pre covered in the stock material from Hawks. I'd assume a can of spray adhesive (headliner glue) would work with the material.
Old May 17, 2015 | 07:17 PM
NASCAR's Avatar
Car: 89iroc/03dakota
Engine: 350&4.7
Transmission: auto
Axle/Gears: 2:77 & 3:55
Had mine covered in tweed 3 years ago at a interior shop. Also had speaker covers done. No problems as of now.
Old May 19, 2015 | 12:20 PM
SolarGoldRaptor's Avatar
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
You don't need "basic glue", you need high temperature contact cement. It's not very expensive and can be applied with a brush. It is very strong once dry.
Old May 19, 2015 | 06:09 PM
DonW's Avatar
Car: 1983 Z28
Engine: Carbed 305
The foam backed headliner material sticks great to the abs plastic headliner with 3M super spray adhesive. I have some around here somewhere and might be able to post a pic, but it is available at local parts houses and hardware stores. Works good under cut-pile carpet too ;-)
Old May 19, 2015 | 06:12 PM
DonW's Avatar
Car: 1983 Z28
Engine: Carbed 305
I must say though, the key to a long lasting installation is in the prep work. Make sure you scuff the plastic with some sand paper and then clean with rubbing alcohol thoroughly. Then the glue will stick and hold really well.
Old May 19, 2015 | 06:23 PM
DonW's Avatar
Car: 1983 Z28
Engine: Carbed 305
Oh, and the trick of the trade is to have lacquer thinner on hand. Available everywhere. It cleans up any glue that goes where its not supposed to, including your tools, hands, etc. Our detail shop used it to clean gum, grease, etc out of seats and carpets. Works wonders on stains etc, and wont fade the material despite popular belief.
Old May 20, 2015 | 05:27 AM
I wouldn't trust a generic glue for a long lasting job.
Old May 20, 2015 | 09:14 AM
DonW's Avatar
Car: 1983 Z28
Engine: Carbed 305
Its been looking great in my Blazer for the last two years. I might be a little concerned about a t-top car though where it will get pelted by the wind though....hmmm Contact cement may be the way to go on a t-top...
Old May 20, 2015 | 09:31 AM
DonW's Avatar
Car: 1983 Z28
Engine: Carbed 305
Nah, I would use it again. I just went out to my blazer and its stuck on as good as the day I did it two years ago. It is foam backed material on ABS and this is the glue I used. It is available anywhere, but I would definately not call it generic. 3M makes some good products, and this was about 10-12$ a can and worked great. Its even heat and moisture resistant...says so right there on the can
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
86IROC112
Nov 7, 2015 06:50 AM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
MORREALE5
Sep 13, 2015 09:01 PM
m00n420
Sep 11, 2015 02:39 PM
