New Headliner............
Old May 30, 2015 | 03:16 PM
MSgt Luttrell's Avatar
Car: 1986 IROC Z28
Engine: Carburated small block 454
Transmission: Level 3 Raptor 700R4 2600 stall
Axle/Gears: Strange S60 3:73 S Trac Posi
Ok, the wife and I replaced the old nasty headliner with a new one this morning, it went pretty well and neither one of us are sporting band aids. Here is what the old one looked like........
Here is what the new one looked like in comparison......................
Here the car is with the old one removed................
While we had it apart, we rerouted the 'hide away' antenna from the roof line to the floor and grounded it under the back seat.
Here the new head liner is installed............
Here is where the new dome light/map light assembly will go, it's on order and should be here sometime this week.............
Here is a pic of the stock dome light/ map light assembly we ordered; after a lot of searching, we found it on Ebay for 17 bucks. Other sites wanted 30 bucks for just the lens.......
Old May 30, 2015 | 03:57 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Re: New Headliner............
Any pics from the top with the t-tops off? where did you get the headliner from?
Old May 30, 2015 | 04:51 PM
WTR388's Avatar
Car: 87 Trans Am
You'll like that light, I went from the plain Jane dome light to the one you're getting.
Big suggestion: Replace the bulbs with the phillips LED bulbs. Sure, they aren't cheap, however they work great, especially the map lights.
Old May 30, 2015 | 05:00 PM
Car: 1986 IROC Z28
Didn't think to take any with the T tops off, I'll post some the next time I have the tops off. I bought the headliner from stock interiors.
Old May 30, 2015 | 09:45 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Thanks. Im looking to replace mine soon and trying to find pics of what it looks like with the tops off. I have heard the abs ones leave big gaps and some say it fits nice so I'm trying to find a brand that will fit my picky needs
Old May 30, 2015 | 09:54 PM
Car: 1986 IROC Z28
I did notice a slight gap at the back of the t tops, but nothing that I considered a show stopper; especially considering what we took out of the car. It was horrible and the interior looks like a new car in comparison. The dome light assembly will be here this week and I'll get some pics posted up with the tops off when I install it later this week.
Old May 31, 2015 | 05:23 AM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Looks real good MSgt Luttrell !!
Your Bride is a keeper, helping you out on the car !!
Old May 31, 2015 | 11:50 AM
Humphrey Lees's Avatar
Car: '82 Camaro
Engine: 305ci (SUJ) not crossfire
Transmission: TH350
Axle/Gears: Stock
Is this a recovered liner or is it a complete unit?
I tried recovering mine and failed dismally as the stuff would not stretch enough around the inside corners.
What material did you use?
Old May 31, 2015 | 02:40 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
its an aftermarket headliner
Old May 31, 2015 | 03:54 PM
Car: 1986 IROC Z28
Yeah, it was an after market headliner and came already finished and ready to install.
Old May 31, 2015 | 06:16 PM
tglennon11's Avatar
Car: 87 IROC
Axle/Gears: LS1 10bolt w/ 3.73
i have been looking for an antenna like that, hows the sound with it? Which model do you have.
Old May 31, 2015 | 07:21 PM
Car: 1986 IROC Z28
The hide away antenna did help some, but not as much as I thought it would have; I picked up a couple more stations, but still no where near as many as my other rigs do.
Old May 31, 2015 | 09:41 PM
WTR388's Avatar
Car: 87 Trans Am
I have my antenna shaved, I'm using one of those antennas that has "wings" to each side of it, double sided tape to the top of the windshield almost tucked behind the head liner. Can't see it from in or outside the car unless you really look and it picks up signals pretty good... I'm really used to satellite radio in the truck so it's hard to say exactly how good it works, but I'm happy for $18
Old Jun 1, 2015 | 01:01 PM
95Cam86Roc's Avatar
Car: 86 Iroc
Engine: LS3
What adhesive did you use? Any pointers for someone looking to install one for the first time?
Old Jun 1, 2015 | 03:32 PM
Car: 1986 IROC Z28
I didn't use any adhesive, the new headliner came already complete and all I had to do was remove the old one and install the new one.
Old Jun 2, 2015 | 03:14 PM
RaisinHale's Avatar
Car: 85 IROC-Z
Engine: 355 SBC
Transmission: Powerglide
Axle/Gears: Moser 35 spline w/ 4.56 gears
I did this on my hardtop last week, but I bought headliner material from Hancock Fabrics. With my online coupon I got the material for $14 and used spray-on adhesive from Lowe's. I think my total was around $20. The hardest part was tearing the old liner out without destropying the molder piece underneath. I'll post some pics of the completed one later.
Old Jun 2, 2015 | 03:51 PM
Car: 1986 IROC Z28
I certainly would have gone that route, had the old backing not been so deteriorated; it basically fell a part as we removed it from the car.
Old Jun 3, 2015 | 01:09 PM
Car: 1986 IROC Z28
Ok, the new dome light/map light came in and I installed it today; it took a little more trimming on the mount hole in the headliner, as it's a lot bigger than the old one it was replacing. I also had a no power issue to the dome light that I traced to behind the dash where somebody had disconnected the wires; got it all lined out and it looks great.
Here are the pics I promised of the head liner with the tops off, there is a little bit of a gap, but nothing that will keep me awake at night.
Old Jun 3, 2015 | 05:07 PM
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
What color fabric is that?
Old Jun 3, 2015 | 06:09 PM
Car: 1986 IROC Z28
The color was 'Very Dark Grey' it's listed on their site under the 1986 camaro interior colors. http://www.stockinteriors.com/items....maro_Headliner
Old Jun 5, 2015 | 05:48 PM
georgiaslim45's Avatar
Car: 1986 Camaro Z28
looks great I got my headliner replaced yesterday. Feels like new car.
